- Thank you received: 65
Toffee tin transmitter
- ronstv
- Junior Member
10 Mar 2016 10:53 - 10 Mar 2016 10:56 #1
by ronstv
Toffee tin transmitter was created by ronstv
Here is a little project i started last night, my toffee tin single channel transmitter
Using 2.4ghz frsky hack module and one of Phil_G's single channel encoders.
With it's hinged lid there is actually enough room inside to fit a few toffee's in so its just the job for a quick snack while flying!
Once for Right, Twice for left, here we go!!!
Ron
Ron
Last edit: 10 Mar 2016 10:56 by ronstv.
Thanks: Quorneng, old fart
- ronstv
- Junior Member
13 Mar 2016 11:29 #2
by ronstv
Replied by ronstv on topic Toffee tin transmitter
Here is a short video of me flying the sharkie with the toffee tin tranny
I was on my own so the quality is not too good but you can see the model half way through and the landing is clear.
This was taken this morning at the club field. The wind was almost flat calm.
Ron.
Ron.
14 Mar 2016 22:29 #3
by The Beard
Replied by The Beard on topic Toffee tin transmitter
can we see inside have you built it from scratch and is it one channel or what does it do
- Thank you received: 14473
14 Mar 2016 23:47 #4
Replied by Eric on topic Toffee tin transmitter
Beardy either didn't read - or hasn't understood - post 1 :lol:
15 Mar 2016 10:06 #5
by The Beard
can I go for 2nd option I would like to understand how it works thanks Eric
- ronstv
- Junior Member
15 Mar 2016 22:17 #6
by ronstv
Hi beard
Basically it emulates the old escapement system.
It has only one push button on the transmitter.
1 press gives you right rudder, 2 presses gives you left rudder, release the button for center rudder. 3 presses gives you kick up/down elevator if fitted. A quick press gives you a sequential 2 or three position throttle. Sounds complicated but it's actually quite simple to operate. See video above. The sharkface is rudder only and it's quite controllable.
I did build it from scratch but used a pre built encoder by Phil_G and a frsky D series rf module.
It's full range 2.4ghz with simple telemetry.
Very easy to build and fly with. See singlechannel.co.uk for more info and how to build one. It's very interesting and a bit different from the norm.
Ron.
Ron.
15 Mar 2016 22:28 #7
by The Beard
thanks ive been told about this sort of system called bang bang .Im told it was when a servo was a weeks money so you used as few as possible its facinating thanks
Thanks: ronstv
Time to create page: 1.011 seconds
