What went wrong and why ?
16 Oct 2016 10:39 #1 by Garry Pollard
What went wrong and why ? was created by Garry Pollard
Went flying Tuesday and Saturday this week and took the Pulse 125 both times
Set up is Spekky DX 7 Tx, 6 channel spekky RX with satellite 8 s power from 2x 4s 5000 mah lipos, switch to power both radio and motor. DSM 2
Tuesday had 4 flights out of the Pulse, not a prob. Saturday installed the 2 lipos switched on the TX then the model switch, ie RX and motor ESC gave its usual bleeps, but nothing on any control surface or motor. I always take spare lipos with me to the pilots box, cos its a long walk at Langar, so lipos were swapped. Nothing , totally dead.Not even a bleep to say the ESC was armed.
Back to the pits , wing off , and tried rebinding. Bind plug in , both rx and satellite flashing happily, turned on the TX with bind button depressed, and the lights happily ignored the TX completely.
Put the model back in the car, and on my return home dug out an identical RX and satellite, took out the old one, and the new one works perfectly .
I know the prob is that the first RX has gone faulty, my question is WHY?
It will be intersting to see what Spekky say about it. Poss as in the past "Nothing was found, but to give you peace of mind we enclose a new unit "
Anyone any ideas? and NO, I will not change to Futaba :woohoo: :woohoo: :evil: :evil:
16 Oct 2016 11:26 #2 by Monz
Replied by Monz on topic What went wrong and why ?
I had something similar with a Spektrum rx, I opened it up and there was a minute solder bridge on the throttle signal pin, ran the soldering iron between joints to clean it up and it worked fine after that. Could you have something similar which has come loose under vibration and is now causing a short?
Thanks: Garry Pollard
16 Oct 2016 15:00 #3 by old fart
Replied by old fart on topic What went wrong and why ?
If ou're going to repair a solder bridge, you need to flux the solder first. ;)
16 Oct 2016 15:40 #4 by Quorneng
Replied by Quorneng on topic What went wrong and why ?
If I read your post correctly initially it armed but no power to the motor and servos. With a change of LiPo nothing at all but back home on a different Rx it all worked.
With that degree of fault variation it begs the question has the old Rx failed or is there a poor connection somewhere?
So my suggestion is get it all working and then put in the old Rx back in straight away. If the old Rx still does not work you can be pretty certain that is the problem particularly if you put the alternate back in again and it all comes to life. Work/fail/work is a pretty stringent component test.
16 Oct 2016 17:50 #5 by Garry Pollard
Replied by Garry Pollard on topic What went wrong and why ?
Thanks for the replies folks, much appreciated.
I think both Monz and Q were right, as I installed a 7 channel rx and all worked . So back in with the 6 and nothing. So out on the bench, 6 v put into the rx after inserting the bind plug, straight away the flashing lights and it bound,.took out the bind plug and dead, so waggled the power plug and both lights on, waggled again and both off. Seems as Monz said a bad connection , but my soldering skills are not up to repairing it so sending to HH tomorrow. Monz spotted the fault and Q posted the correct way to check. Thanks to both of you
16 Oct 2016 20:27 #6 by Eric
Replied by Eric on topic What went wrong and why ?
Glad you solved it, Garry, but if you recall, I had a similar problem a week or so ago, with the Excalibur, with the top off, it worked fine, put the top on, and everything shut down.
It proved to be the commercial XT to Deans adapter I'd used. With the top on, there was enough pressure on it to break the poorly soldered connection inside.
(Solution - cut the XT off, and fit a Deans, with a short extension, because the existing cable was 3cm too short for easy connecting! )
((Before someone shouts that XT's are better - I read that XT's are intended to handle 60 Amps, and a Deans is intended for 65 Amps! ))
P.S Another reason I don't like XT's is the plastic casing provides some of the friction-fit, and we had an instance at the club where the XT was REALLY tight, but the connection was intermittent. It turned out that the female of one of the 'poles' had spread out, and was a very sloppy fit. With a Deans, ONLY the pins make any connection with the mating half.
Sorry for hijacking your post, Garry, but it may just solve someone else's intermittent fault.
16 Oct 2016 20:53 #7 by Garry Pollard
Not a prob Eric, and I DO remember the post you mentioned
17 Oct 2016 09:36 #8 by one tenor
Replied by one tenor on topic What went wrong and why ?
Hi Monz can you clarify something for me ? Were you removing the solder bridge ?
17 Oct 2016 16:12 #9 by Monz
I think I could have made myself a bit clearer. It wasn't an intentional solder bridge joining two parts of a circuit, it was a manufacturing fault within the rx where a bit of solder between the live and signal pins was present, causing a short between them. I ran the soldering iron between the two pins and removed the offending bit.
"A solder bridge is an unintended electrical connection between two conductors by means of a small blob of solder."
17 Oct 2016 16:33 #10 by The Beard
Replied by The Beard on topic What went wrong and why ?
Ive a new Receiver that refuses to bind popped a used one in and model worked perfectly so sending it back to Sussex Model centre
17 Oct 2016 16:40 #11 by Garry Pollard
Thanks for that Monz.
Well I have sent my faulty one back to HH , will post their response as soon as it lands It will be interesting, as its a DSM 2 model 6200
17 Oct 2016 18:15 #12 by Quorneng
You might have spent more on shipping that it is worth!
As an example you can get one here for $14.75 with free shipping! :woohoo:
I will be interesting to see what Horizon do. ;)
17 Oct 2016 18:25 #13 by Garry Pollard
As it was very light, and only going to Harlow it cos £2 . I must admit I am curious to see if they will acctually repair it. However, thanks for the link Q, thats a new one on me
17 Oct 2016 20:33 #14 by one tenor
I thought that was it just making sure. I have seen the odd deliberate bridge. Thanks Monz
23 Oct 2016 04:12 #15 by locky
Replied by locky on topic What went wrong and why ?
In my years of experience I can inform you sir the issue was not enough methanol . :whistle:
Thanks: Klipkopwildlife, Flytilbroke, boz
Time to create page: 0.847 seconds
