Lipo charging
03 Mar 2018 11:05 - 03 Mar 2018 14:51 #1
Lipo charging was created by Klipkopwildlife
This subject has reared its head again, we used to have a British Army document on the site that gave us full charge voltage v temperature. On this chart it can be seen that the full charge voltage at 30oC is considerably higher than at 5oC. The problem is the charger detects certain minuscule changes in the charge current when the Lipo is full, this is independent of temperature and here is the problem, I used to charge when I returned from flying, the temperature would often be 25 - 30oC. I would then disconnect from the charger (never leave a battery connected and unattended) and leave things overnight. Then gaily go off flying the following morning. The problem is the 20oC drop in overnight temperature. The battery at 5 - 10oC is now seriously overcharged! And puffs up.
Since I started charging my batteries in the morning before flying I haven't had a problem because I'm now charging at a lower temperature that's rising.
Last edit: 03 Mar 2018 14:51 by Klipkopwildlife.
Thanks: Flytilbroke, THE BLACKBIRD, boz
- Mike Rolls
- Thank you received: 573
03 Mar 2018 15:08 #3
Replied by Quorneng on topic Lipo charging
To be fair the set of instructions with my latest LiPo does state quite clearly that the battery should only be charged when it has fully cooled down.
Like you Klippy I always charge early on the day I fly, except when I am off to a meet but even then the batteries are charged at room temperature.
- Thank you received: 14470
03 Mar 2018 16:56 #4
Replied by Eric on topic Lipo charging
Mine are charged outside, on the concrete floor, at more or less ambient temp, the day before I want them (usually!), but are stored inside at room temperature, which is normally (when the heating works!) a lot warmer!
The only timing exception is when I've charged up ready to go, and the weather says oh no you aren't! :evil:
Thanks: THE BLACKBIRD, boz
- Thank you received: 10844
06 Mar 2018 21:00 - 09 Mar 2018 06:55 #5
Replied by THE BLACKBIRD on topic Lipo charging
Here's my charger and power supply for it, one side pack up 6 months after i got it , and today it kept shutting off telling me the input voltage was low, so it looks like its all going to quit on me,
:evil:
Measure the input voltage from the power supply to the charger please. Both plugged in to the charger and unplugged.
Last edit: 09 Mar 2018 06:55 by Klipkopwildlife.
08 Mar 2018 19:47 #6
by one tenor
Replied by one tenor on topic Lipo charging
Sounds like dry soldered joints to me . Give it a going over with a soldering iron.. It's worth a punt.
08 Mar 2018 20:25 #7
09 Mar 2018 03:09 - 09 Mar 2018 03:25 #8
by one tenor
A pity I'm so far away I'd have a go at the soldering for you .Agh but then I couldn't test it properly as I've no Lipos
Just a thought isn't it still under warranty/guarntee ?
Last edit: 09 Mar 2018 03:25 by one tenor. Reason: additional script
Time to create page: 0.686 seconds
