Digital multi meter
06 Mar 2018 11:17 #1 by Klipkopwildlife
Digital multi meter was created by Klipkopwildlife
BB needs some tips on using a multi meter that he bought and has lost the instructions! The next post will be a picture of it, I hope!
06 Mar 2018 17:37 #2 by Eric
Replied by Eric on topic Digital multi meter
If you can make out the model number and manufacturer - google it!
06 Mar 2018 20:55 #3 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Digital multi meter
here it is Klipy
06 Mar 2018 22:25 - 06 Mar 2018 22:26 #4 by Quorneng
Replied by Quorneng on topic Digital multi meter
Black lead in the centre socket and the red lead in the right hand one Turn dial to read whatever you are trying to measure.
The only exception is if the current is more than 250 mA you have to move the red lead over to the left hand socket and turn the dial to the 10A position.
The right hand upper button is for the LCD back light. The left hand button holds the reading on the display even after you have removed the probes.
But the thought of using hand held probes on a 600V source really worries me! :woohoo:
Last edit: 06 Mar 2018 22:26 by Quorneng.
07 Mar 2018 11:39 #5 by THE BLACKBIRD
So how do i measure my batteries as that is what i bought it for, it has white, green,red lettering
07 Mar 2018 12:44 #6 by Klipkopwildlife
Replied by Klipkopwildlife on topic Digital multi meter
Ok, the only measuring you'll do with this meter is the battery voltage. Start by turning the dial to the left to the white lettering, this is Volts DC, for Direct current, which is why you have the white stripe after the 'V'. It's pretty hard to damage this kind of Voltmeter, turn the dial to 200 and then poke the probes into the battery connection socket. It's usually a good idea to have the bit that your poking probes into, securely held. I have a little vice with removable rubber jaws which works very well. The last thing you want is the connector shying away from you while you're trying to push probes in! Most damage caused by multi meters is the damage caused when the probe shorts (connects 2 tracks together) stuff that it shouldn't. With the probes inserted, it doesn't matter which way round, read the number on the screen. If it's less than 20 remove the probe, turn the dial to 20 and try again. If the leads are reversed (+ve to -ve and -ve to +ve) then the reading will have a - (minus) in front of it.
For the moment never change the dial while both probes are connected.
07 Mar 2018 15:31 #7 by THE BLACKBIRD
its not a very good meter then, i just tried it on a 2s 2200 lipo and it read 17.3 then on a 4s 4000 and it read 32.4 then on another 2s 2200 it read 17
The 2200 s were out of the revolver, i need to get another tester my one got burnt when a 4s went pop a couple of weeks ago
07 Mar 2018 15:44 - 07 Mar 2018 15:46 #8 by Eric
Those numbers aren't right, BB
A 2s lipo (the C rating is unimportant) should be about 7v when it is low, and about 10 when it is charged.
A 1S cell shows around 3.5 when it is low, and 4.8 full.
A 4S should be (3.5 X 4) = 14v flat and ( 4.8 X 4) = 19.2 full
Are you sure you were wearing your reading glasses? [badass]
Last edit: 07 Mar 2018 15:46 by Eric. Reason: added a word
Thanks: THE BLACKBIRD, boz
07 Mar 2018 16:47 #9 by THE BLACKBIRD
LOL yes Eric they were the numbers that came up, i know they cannot be correct
07 Mar 2018 17:13 #10 by Klipkopwildlife
Are you sure those 2200s weren't 3s?
Now you're going to take an AA or AAA battery or 2 and measure its voltage. I'd be interested to know the result, also to know if the readings are different when you reverse the leads.
07 Mar 2018 18:12 #11 by Quorneng
Those reading are exactly twice what I would expect from a 2s and a 4s. I don't think that is coincidence but I can't imagine why it would double read..
07 Mar 2018 18:15 - 07 Mar 2018 18:18 #12 by Quorneng
I don't suppose you had the knob tuned to the AC volts (to the right instead of to the left)? It reads exactly double on my meter if you do! ;)
Last edit: 07 Mar 2018 18:18 by Quorneng.
07 Mar 2018 20:00 #13 by THE BLACKBIRD
Yes Simon that is exactly what i did :silly: :S :whistle: if thats all i can do with it just checking voltage then it not much use to me
07 Mar 2018 22:05 #14 by Quorneng
I suppose it all depends on exactly what you want to measure!
If its anything to do with "power" electrics, as in electric planes, then it is not really the right instrument. A multi meter is fine (and very accurate) for voltage, resistance and fractions of amps but no use for measuring the sort of amps that brushless motors and LiPos can dish out.
For that you need a Watt meter like this as it can measure a big current. It also tells you the voltage and the Watts being used at the same time.
08 Mar 2018 13:05 #15 by Klipkopwildlife
THE BLACKBIRD wrote: Yes Simon that is exactly what i did :silly: :S :whistle: if thats all i can do with it just checking voltage then it not much use to me
Hmm, colour blind as well as dyslexic! [badass]
Right so now you know how to measure DC voltage. Now we're going to measure some DC current. First set up a Ubec feeding a receiver with a servo. Set up as you would normally and check that it works, measure the voltage into the receiver while you're at it.
Now, take an old servo extension lead and cut the black about half way along, bare the black wires back about 1/4". Plug this lead between the Ubec and the RX. Now turn your meter dial to the 10Amp setting and move the red probe to the left hand socket. Then connect your probes, one to each black wire.
You should now be able to see the rest current of the RX plus the servo. It should only be fractions of an amp, try waggling the stick to see how the servo draws more current. Try stalling the servo, see how the current gets much higher.
Time to create page: 0.921 seconds
