Soldering
- Away
- Thank you received: 10844
Even soldering servo wire I use the 100w iron, makes for a quick heat up without melting the covering
Now I have got into the silver soldering it has opened up a new life with the things you can do
And contrary to.poplar believe it's not hard to do
- supertigrefan
- Thank you received: 513
I've been using rosin cored, lead free and it's fine as long as it's heated well and the joint is clean, leaded solder is easier to use as it's more forgiving, Bakers fluid is good for preparing heavy wire like U/C's but is highly corrosive so needs to be neutralised and washed away afterwards, I use rosin as flux most of the time, the stuff in the tin that comes as a solid block then crush what I need and add Acetone to liquify it.
Silver solder is excellent and opens up another world, I actually find it easier than soft soldering and it's claimed to be near to a weld in strength, the game changer however is Aluminium brazing....Wow! what a revelation, it takes a bit of practice but is well worth it, IT IS as strong as a a TIG weld and as a bonus, has also saved me a few bob with repairs to the air con on the car....it's a no-lose situation.
- Ralpharr2001
- Thank you received: 1484
- supertigrefan
Ablemablecrafts on EBay
Sorry, tried posting a link but just kept getting an error message.
P.S.look for P.M.
- supertigrefan
Ebay solder rods
Edit- Looks like it hasn't, how do I post Ebay links?
In your browser click on your address line until it goes blue, then right click on it and select copy. Above your post there's a line of Gui's, 8 from the right is a chain link, left click on it and 2 boxes will come up, right click on the left one and select Paste. Left click on the right one and type in what you want the link to say. Make sure your cursor is in the right place and click add. This is the method I've found works.
Thanks for the heads up STF
- Away
Many thanks to all who gave the excellent advice. My temperature controlled iron is only 37watts so I think I'll have to go back to my trusty old Weller, not adjustable except by changing the tip. All the years I've used a #7, looks like I'll have to change to a #8, if I can find it!
- Thank you received: 14470
Modern rubbish lead-free solder is a nightmare to use, as stated, the iron needs to be a lot hotter, and you need a lot more flux, and still get grotty-looking joints.
Also, if a joint (or iron!) has been used/done with regular leaded solder, the lead-free will not mix with it, but just puddles on top. You have to clean the surface down to original metal, before you stand a chance.
Also - obviously - as you are running the iron hotter, the tips don't last as long, either.
The stuff was developed for the commercial industry, using dipped bath techniques, and they now get a lot of rejects, for some strange reason! The idea was to remove the possibility of lead poisoning from the fumes. (EU again??)
Regular tin/lead multicore solder is easily obtained for the hobbyist, even HobbyKing are selling it now, but look on e-bay, etc, for better prices.
- supertigrefan
Any questions, please ask.
- crash happy
- Thank you received: 1203
That's worth knowing, thanks.
I still have some of my fathers left from his amateur radio days. Best stuff iv'e ever used but it wont last forever!
- Away
