- Thank you received: 14473
Soldering
- Thank you received: 10844
- Flytilbroke
- Thank you received: 1987
I neither like nor trust those XT plugs and sockets, you can never tell if it is the pins that are tight, or just the plastic case. People have lost models because of that, a tight fitting case and a broken female receptacle in the thing. With a Deans, there is no case!
The best way I have found is to use a big iron (200W with a 4 oz (250g) copper bit. That only requires it to be dabbed on for the solder to flow minimising heat transfer elsewhere but it does take far longer for the iron to heat up than to solder the joint!
- Flytilbroke
OUCH!
