Sticky feel
29 Jan 2022 13:09 #1
Sticky feel was created by Klipkopwildlife
Here's the thing, I have a number of items that were supplied with a 'soft touch' covering, a magnifying glass for one and a GoPro camera for another. This is fine when the item is new but in our very hot climate the surface becomes sticky and readily picks up dirt, even to the extent of the stickiness coming off on your fingers.
Does anyone have any ideas about how to fix the problem? I don't want to throw away or replace the items, okay you can call me Scrooge if you want.
- Thank you received: 14470
29 Jan 2022 17:28 #2
Replied by Eric on topic Sticky feel
Keep them in the fridge! [badass]
Try dusting them with talc or french chalk! (not the lens!)
29 Jan 2022 20:27 #3
Replied by Quorneng on topic Sticky feel
Polyurethane spray.
Just make sure you mask the lens!
30 Jan 2022 07:23 #4
Replied by Klipkopwildlife on topic Sticky feel
I had hoped to find something they could be wiped with to mop up the stickiness.
30 Jan 2022 09:19 #5
I suspect you will find that it is the plasticiser that is breaking down, and after a while the 'rubbery' surface will begin to break up.
- Flytilbroke
- Thank you received: 1987
30 Jan 2022 09:22 #6
by Flytilbroke
Replied by Flytilbroke on topic Sticky feel
A very common problem that sticky-ness. I have not found a decent cure yet.
Time to create page: 1.474 seconds
