AM 15 diesel
  • Rich griff
24 Feb 2022 14:27 #1 by Rich griff
AM 15 diesel was created by Rich griff
Stripped but left crank in situe, cleaned, checked, reassembled and lubed.
Mounted in test mounting and ran up.
Little difficult to start untill settings established, then a good easy starter.
The bugger bit me but no blood.
Rich runs then leaner and a final brief period onso g lasting 5 seconds or so.
Noisey but good potential.
Conical piston, I reckon it's the later "2" version measuring piston size.
Lubed and stored awaiting a period cl model to be made.
Os glow "pet" next.
D1000 fuel.
24 Feb 2022 14:47 #2 by paul d
Replied by paul d on topic AM 15 diesel
Good engines! I recently sold a AM10, loved to rev and was quite light, sort of wish I'd kept it now...
24 Feb 2022 21:27 #3 by Quorneng
Replied by Quorneng on topic AM 15 diesel
I suspect it is a later AM 15. Mine has a blue anodised head.
25 Feb 2022 07:30 #4 by paul d
Looks nice Simon, you need to get some fuel and give it a run just for old time sake.
  • Rich griff
25 Feb 2022 14:47 #5 by Rich griff
Replied by Rich griff on topic AM 15 diesel
Yes, blue head/cylinder jacket on 15, green on a 10.
Paul, may I ask, how much did your am10 achieve ?
25 Feb 2022 14:56 - 25 Feb 2022 15:00 #6 by paul d
£40. Rich, went to friend so couldn't ask to much and I did only give a tenner for it although it was gummed solid and needed a conrod, there's pictures of before and after on here somewhere?
Edit: found the before picture!
Last edit: 25 Feb 2022 15:00 by paul d.
25 Feb 2022 23:08 #7 by Quorneng
The AM 15 is certainly fiery but my favourite is the ED 246.
Powerful in its day, it even sounds powerful with a relatively deep note rather than the sharp crackle of the AM.
I still have its 9x6 "Trueflex" prop which added to the power impression as its tips flexed forward noticeably at full chat. ;)
26 Feb 2022 07:16 #8 by Klipkopwildlife
Replied by Klipkopwildlife on topic AM 15 diesel
As a youngster I aspired to an ED 246, could never afford one!
26 Feb 2022 07:58 #9 by paul d
Better known as "the racer", Simon, I believe yours is a mkiv, if you post the serial number I can tell you how old it is.
Some of those later green head racers were available from the factory as Reed valve induction rather than disc valve, ED never advertised the fact for some strange reason.
26 Feb 2022 11:14 #10 by paul d
Edit to the above...Its actually a mkiii Reed valve motor..
Time to create page: 0.629 seconds
