How things have changed
15 Jun 2022 08:42 #1
How things have changed was created by Klipkopwildlife
Since my sister is unable to collect the Bucker on her trip to the UK I've been looking around for a suitable kit or scratch build project to put a DLE-55RA into. My thinking is SMC have one at a reasonable price and I'm going to need one when the Bucker eventually arrives.
While doing comparisons I remembered that I bought a NiB Zenoah 23 some 12 years ago, when I eventually found it, I weighed it flight ready, 1.65Kg or 3.6lbs in real money. A cross check on the DLE shows 1.565Kg flight ready, or 3..44lbs.
The Zenoah turns an 18x8 at 7k rpm, the DLE 23x8 at the same revs, it makes me wonder if it's worth putting the Zenoah into anything!
- Thank you received: 14470
15 Jun 2022 09:28 #2
Replied by Eric on topic How things have changed
A self-propelled door-stop? [badass]
- Flytilbroke
- Thank you received: 1987
15 Jun 2022 09:44 #3
by Flytilbroke
Replied by Flytilbroke on topic How things have changed
Instead of A Bi-plane think Mono-plane for the Zenoah.
15 Jun 2022 09:53 #4
Replied by Quorneng on topic How things have changed
The Zenoah 23 is basically a car/boat engine design so is likely to be heavy/low powered compared to one designed specifically for aircraft use.
Even the G23 (glow on 15% nitro) still uses the same basic parts. On the plus side it is probably pretty indestructible.
15 Jun 2022 12:23 #5
Was it not originally a chainsaw/strimmer engine?
15 Jun 2022 12:28 #6
Replied by Klipkopwildlife on topic How things have changed
It's marked G230PU which is supposed to be for aircraft use. As much as anything I was gobsmacked at how power to weight ratio has changed. I bought it for a Glens models 68" CAP 232 kit that I got from somewhere, the Zenoah was one of the recommended power plants.
- Thank you received: 10844
15 Jun 2022 15:58 #7
Replied by THE BLACKBIRD on topic How things have changed
Zenoah were designed for the chain saw market and adapted into model aircraft use, and i would say they are still one of the most poplar engines even today a lot of the scale builders use them
I have the plan for the Bucker Tony if you want to scratch build
15 Jun 2022 17:34 #8
Thanks Tony, it's a thought.
I see Glens models recommended the Zenoah ZG23 which has a rearward facing carburetor. Mine has a sideways carburetor, I can't see it's going to make much difference, the ZG has a right angle manifold for the carburetor which I feel will reduce power somewhat.
Thanks: Eric, THE BLACKBIRD
Time to create page: 0.644 seconds
