Polyc Review
01 Mar 2012 04:16 - 01 Mar 2012 04:18 #1 by Ex-Member
Polyc Review was created by Ex-Member
POLYC
Polyc a users review.
Poly-C™ is an industrial Polyurethane water based varnish with an additional additive that is used to cover models with Nylon, Tissue or Glass cloth. It is very similar to glass resin although there is no mixing and it is water based. It usually dries in 20 - 30 mins in a room temperature and although it doesn't dry as hard as glass resin it certainly is strong enough for a light weight covering.
This is the first time I have ever used this product normally being a tissue and dope man, so I approached it with some trepidation.
But I should not have been worried as it is far easier to use than my favored dope and tissue.
I am building a Tony Nijhius Hawker Hurricane and have been debating what to use as a covering for some time, glass and epoxy would have I feel covered the open structure of the frame to much making it look sheeted when it wasn't.
Solatex was a unknown to me as I have never used it.
So when I came across Polyc I had to buy some to try, mainly because I could use heavy weight tissue as my covering material.
Now they say that you cannot use Poly c on an open structure and as I had made my wings lighter by doing away with the sheeting I was a bit concerned, but again I found that there was nothing to worry about.
Polyc being water based might have warped the balsa so I started my wing by applying 2 coats of sanding sealer to seal the wood.
I then laid a dry sheet of tissue on the wing and painted the Polyc through the top of the surface and allowed it to soak into the tissue, but only onto the sheeted sections, I left the open sections dry for now.
Once the Polyc on the sheeted sections had dried I then painted a coat onto the tissue over the open section of the wing, it did sag when first applied but once dry the tissue had shrunk nice and tight.
A second coat was the applied and once again left to dry.
When dry the overlapping tissue was trimmed off and the edges sanded down, a third coat was then pained on and that was it, one covered wing.
An hour later the wing was rock hard on the sheeted sections and on the open parts, the tissue was nice and tight and very strong.
The fuselage was done in the same way.
Once the whole plane has been painted a further coat of Polyc will be used to seal the paint. Job done.
So in my own humble opinion Polyc is a good alternative to dope as it does not smell and can be washed off the brushes in plain water.
Cost wise it is not going to break the bank either.
£10.00 for 500mil, which is more than enough for one 62” hurricane.
Polyc can also be used without any covering material or with glass cloth as an alternative to epoxy.
For more information and to buy go to rc world
To sum up.
Polyc is easy to use,clean and non smelling, ok it's not as strong as epoxy but on the other hand it's not as heavy.
10/10.
Tony B. aka Blooper.
Last edit: 01 Mar 2012 04:18 by Ex-Member.
01 Mar 2012 05:31 #2 by The Beard
Replied by The Beard on topic Re: Polyc Review
Ive heard a lot about people using Poly C and your review has made it sound very straight forward and easy/.It was also written and described in a way that anyone can understand the proceedure and gives confidence where maybe the myth of Poly C would have led one to believe otherwise,Thankyou
01 Mar 2012 23:20 #3 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Polyc Review
Told you Tony!
02 Mar 2012 01:36 #4 by Ex-Member
Replied by Ex-Member on topic Re: Polyc Review
yes you did, you smarty pants. :P
but being told and seeing for yourself are 2 different things. :cheer:
02 Mar 2012 03:26 #5 by Quorneng
Replied by Quorneng on topic Re: Polyc Review
Very interesting and well described.
In fact I think it has given me a good solution for a possible future very big, very light build!;)
02 Mar 2012 03:28 #6 by Ex-Member
it seems to get harder over time.
i wonder what the full curing time is.
02 Mar 2012 14:29 #7 by Klipkopwildlife
Tony B. AKA Blooper wrote: it seems to get harder over time.
It gets like that when you're over 65 Tony!:(
02 Mar 2012 16:16 #8 by Grumpy42
Replied by Grumpy42 on topic Re: Polyc Review
What? what? What gets harder over time??? Is there hope for me yet? Errrrrrr - now I'm 69 - so - how MUCH time???? :unsure: :unsure: :unsure:
  • gillyg1
18 Dec 2012 03:44 #9 by gillyg1
Replied by gillyg1 on topic Re: Polyc Review
it also makes a good matt fuel proofer, glow/diesel/petrol, engine bay fuel soaked wood, brilliant:)
  • gillyg1
18 Dec 2012 03:46 #10 by gillyg1
if you want a gloss fuel proofer :- "ezekote" from deluxe materials, same water based product.;)
18 Dec 2012 12:39 #11 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Re: Polyc Review
I seem to be the only one thats having problems with it :( it is still lifting off the SR71 :S i applied it on top of sanding sealer, maybe i got the surface to smooth.
Looks ok on the fence though :P :P :P
18 Dec 2012 22:29 #12 by Eric
Replied by Eric on topic Re: Polyc Review
Not just you, BB, when I tried it, the genuine poly c foamed up and made a horrible mess. :(
22 Jan 2013 15:26 #13 by Ex-Member
Replied by Ex-Member on topic Polyc Review
wrong brush and scrubbing too hard.
but it is horses for courses.
i like it.
you don't.
fair enough.
22 Jan 2013 15:45 #14 by old fart
Replied by old fart on topic Re: Polyc Review
THE BLACKBIRD wrote: I seem to be the only one thats having problems with it :( it is still lifting off the SR71 :S i applied it on top of sanding sealer, maybe i got the surface to smooth.
Maybe it's incompatible with the sanding sealer (cellulose). :unsure:
Time to create page: 2.116 seconds
