- Thank you received: 1987
Blackhorse Travel Air
- Flytilbroke
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
The Beard wrote: u/c fell off again
Your's or the planes? Sowwieeee...couldn't resist :evil:
- Sarah-Jane Smith
- Gone
Stop it hahahaha!!! :whistle: :evil: :whistle:The Beard wrote: .......,Havent tackled the u/c but what worries me is the dreadful left pull this thing has.
- Thank you received: 14470
- Sarah-Jane Smith
- Gone
This reaction involves Newton's Third Law of Physics - which states that for every action there is an equal and opposite reaction. Which translated to planes means that as the internal engine and propeller are rotating in one direction, an equal force is trying to rotate the aircraft in the opposite direction.
When the airplane is air born, this force is acting on the longitudinal axis, tending to make the airplane roll. Today's planes are designed with an engine offset to counteract this effect of torque.
When the plane is on the ground during takeoff roll, an additional turning tendency is induced by this torque reaction. As the left side of the plane is forced down, it is putting more weight on the left main landing gear. This effect results in more ground friction or drag, more on the left than the right causing even more turning to the left.
jhphillips.hubpages.com/hub/Airplane-Torque-4-Types-Explained
this is what I read re Vapor pulling left
- Sarah-Jane Smith
- Gone
wiki.flightgear.org/Understanding_Propeller_Torque_and_P-Factor
On the ground and at slow speed only the undercarriage can generate it, once in the air it can only be generated aerodynamically, either by the ailerons or by yawing the plane so one wing generates more lift than the other.
As Old Fart points out countering engine torque by yawing the plane with fixed side thrust does not work when flying inverted!
As I understand it yawing on take off is a combination of engine torque acting on the under carriage and to a much larger degree by the prop wash being effected by the proximity of the ground causing the twisting column of air to 'bend' so when it strikes a tail fin it causes the plane to turn.
This turning effect largely disappears once clear of the ground although the effect of the engine torque remains.
