Maddog designs nemesis
got the fuselage ready for covering now.
i want to spray this one as an experiment.
so i think tissue and poly c is the order of the day.
the wings will have to be covered with an iron on film though.
one point to add.
be very very sure that you dip your brush into the right container.
sanding sealer and coffee are not interchangeable.
- Thank you received: 14470
ready for primer and spraying.
the next job was to cut out the ailerons from the foam core wings. eeeeeeeeeeeeeeeeeeep
so have a coffee and sit and measure the cut lines, then slurp some coffee and check the measurements again and again for luck.
then deep breath and cut.
if you got it right you will end up with this.
so after another slurp of coffee you can do it again.
you can breath now.
then you can fit the cap strips to the cut outs in both wings, these need epoxying on (pound land twin tube epoxy is good for this, cos you need lots of it)
hold them in place with masking tape to set.
finish your coffee and slop some paint on the fuselage.
Tomorrow i will finish the ailerons and tidy the wing up.
nah...
sanded the wings to shape and tidied up the aileron slots.
then i took a deep breath and cut the ailerons to shape.
measure as many times as you feel is needed then cut.
its messy, very messy, polystyrene every where.
glue on the balsa strips to cover the polystyrene and leave to set.
go get a coffee.
come back and tackle the first aileron servo.
decide which way up you are fitting the servo and make a balsa box with a ply top.
then mark out where it has to go and cut into the nice pristine wing.
dig out masses of the messy stuff, ( balls every where again)
and epoxy the box in place.
get a nice bit of sharp tube and mark where the servo wire run will be and then bore a hole through the inside of the wing, with luck it will line up with the servo hole.
thats one side done.
tomorrow i will tackle the other side and then i am ready to join the wings.
Lots of finger-nail marks in that balsa, skin, Tony!
a thin skim with filler and it will be as good as new.
- RobC
- Premium Member
- Thank you received: 215
