72" lancaster build
01 Jan 2014 20:56 #1 by Ex-Member
72" lancaster build was created by Ex-Member
ordered the plans for a 72" Lanc yesterday, so as soon as they arrive i will be starting this one.
no idea of colour scheme's yet so you will all have to wait.
:P :P :P
01 Jan 2014 22:09 #2 by Eric
Replied by Eric on topic 72" lancaster build
Be a bit different, and build it as a Lancastrian!
01 Jan 2014 23:42 - 03 Jan 2014 00:10 #3 by The Beard
Replied by The Beard on topic 72" lancaster build
Do you mean as a Lancastian would build it
Last edit: 03 Jan 2014 00:10 by .
02 Jan 2014 20:00 #4 by Eric
No, Beardy A Lancastrian was a Lancaster converted to a passenger plane, with a few seats and windows, instead of bombs and gun turrets.
02 Jan 2014 20:53 - 02 Jan 2014 20:55 #5 by Ex-Member
Replied by Ex-Member on topic 72" lancaster build
with neene's for testing
Last edit: 02 Jan 2014 20:55 by Ex-Member.
02 Jan 2014 22:25 #6 by The Beard
WOW like that one Tony looking forward to the build
12 Jan 2014 20:29 #7 by Ex-Member
well the wood has been ordered.
just waiting for it to turn up and then we can get started.
one 72" Lancaster will be getting built.
must get on with the 72" b17 as well.
16 Jan 2014 09:00 #8 by Ex-Member
We have WOOD.
we have plans
we almost have a clear space on the bench.
we SHALL be cutting ribs or formers today.
Let the build begin.
16 Jan 2014 11:01 #9 by old fart
Replied by old fart on topic 72" lancaster build
Is it finished yet? :silly:
16 Jan 2014 16:35 #10 by Ex-Member
sat down this afternoon and cut the tailplane ribs all 14 of them, then we cut a spar and made a start.
you have to build the tailplane upside down, so that the underside has the dihedral.
then you add the trailing edge.
and then the false leading edge and leave to dry over night.
tomorrows job will be to fit the rudder servo mounts, run the servo wires and sheet the underside.
then when dry i can flip it over and sheet the top, make the fins and we are done on this bit for now. :)
17 Jan 2014 13:00 #11 by Ex-Member
well i have glued in the final spar and sheeted the underside of the tailplane, need to wait for it to dry now.
cut out both fins and rudders as well.
will post pics later.
17 Jan 2014 20:25 - 18 Jan 2014 17:20 #12 by Ex-Member
glued the bottom spar in place and then cut the rudders and fins.
then when the spar was set i sheeted the underside of the tailplane.
had to cut 2 holes so i can fit the rudder servo's next, then i can sheet the top of the tailplane and fit the l/e.
another job done.
Last edit: 18 Jan 2014 17:20 by .
18 Jan 2014 16:45 #13 by Ex-Member
rudder sevos fitted.
top sheeting done and the leading edge gluing.
started cutting 21 fuselage formers, long slow boring job.
still nearly done them now and we can start the fuselage soon.
18 Jan 2014 21:16 #14 by Ex-Member
i know it is a bit early but what about this colour scheme.
Just Jane :)
18 Jan 2014 21:24 #15 by The Beard
Yes I think thats the right colour scheme,how I would expect a Lanc to look.
Time to create page: 1.233 seconds
