Flair Etrich Taube 1910
- bogbeagle
- Senior Member
- Thank you received: 119
It is 76"span and weighs 5lbs, wet. Lots of drag.
The model has a Saito .45. ... which is a nice, modest power . I don't believe that I've ever had to use full power, so there is some in reserve ... after all, your Taube is a bit bigger than my model.
You can be confident that it will be fine in your model.
see if you can find the 50, and 45 dimensions from the chart on here, compare them to your 52
saito-engines.info/specifications.html
