TSR2 in depron
26 Jul 2014 17:02 #16 by Ex-Member
Replied by Ex-Member on topic TSR2 in depron
i thought that BB, its just that edf units cost soo much and they produce so little thrust for the noise. :(
well i wont be doing anymore to it now until after the vulcan is finished ( i need more depron) i can have a think and play with some sketches.
depron is soft but once covered it is fairly strong, not as strong as balsa, but then it weighs half the amount. so its a trade off between strength and weight.
i recon the sr71 could be kept under 11lbs if you built it out of depron. hmmmmmmmmmmmmmmmmmmm
26 Jul 2014 17:16 #17 by Eric
Replied by Eric on topic TSR2 in depron
With a pair of Wren turbines in it? :woohoo:
28 Jul 2014 17:25 #18 by Ex-Member
between stretching my back sessions i have been using up the offcuts of 3mm depron on the TSR2 nose area.
ordered some more depron now, so i will be getting the vulcan wings finished over the next couple of days and will get back to this when i am painting the vulcan.
31 Jul 2014 18:40 #19 by Ex-Member
cut some more fuselage formers today.
its Biiiiiiiig :P
31 Jul 2014 18:42 #20 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic TSR2 in depron
I like it, you cannot beat big models , sorry Andy :ohmy: :ohmy:
01 Aug 2014 19:10 #21 by Ex-Member
been cutting a few formers and the wing cores.
02 Aug 2014 18:39 #22 by Ex-Member
spent the afternoon cutting yet more formers while pva was drying on the vulcan.
once i have updated the plans i can glue the other side of the fuselage together.
then i need to look at the wings, so i can sort the wing to fuselage mounts.
03 Aug 2014 13:42 #23 by Ex-Member
well i amended the plan to bring it up to date and sat down and finished glueing all the formers and spines together.
its HUGE really HUGE.
plans are going to be HUGE as well. :P
thats just the middle section of the fuselage.
03 Aug 2014 13:59 #24 by Ex-Member
Looks like you need a bigger set square mate........;-)
Notwithstanding, it's looking good and has just given me the inspiration to go upstairs and do some modelling............bfn
03 Aug 2014 14:14 #25 by Ex-Member
i thought to myself "as its only a 50inch wingspan, it can't be that big a model" ha ha ha ha ha .
The fuselage is only 97 inches long so far and it still needs the nose cone making.
eeeeeeeeeeeeeeeeeeeeeeeeeeep.
now i have a question.
on the original it had an all moving tailplane and fin.
do i try to replicate that or stick to the simpler elevators and rudder system.
also i plan to have flaperons set up on the main wing to help with slow speed flying.
03 Aug 2014 18:18 #26 by Ex-Member
well i have made my own mind up and will stick to conventional control surfaces.
with that in mind i cut the tailplane and fin cores this afternoon.
fin will be mounted like this when it has been skinned and before the last bit of the fuselage is sheeted.
working on the main wing to fuselage mount now and hope to get it sorted Monday/Tuesday.
onwards and upwards. :)
03 Aug 2014 18:51 #27 by THE BLACKBIRD
That wing looks small Tony, but i doooo like it
Think you have found your vocation with this depron young man
Brilliant
03 Aug 2014 18:53 #28 by Ex-Member
and thats with a 20% increase in span over scale. [badass]
03 Aug 2014 19:28 #29 by Ex-Member
Tony B wrote: well i have made my own mind up and will stick to conventional control surfaces.
Good decision Tony, you only need an all flying tailplane if you intend to go supersonic............ :lol: :lol:
03 Aug 2014 19:34 #30 by Ex-Member
now there is an idea. :P :P :P
Time to create page: 0.812 seconds
