- Thank you received: 352
Westland Whirlwind #3
- chookman
- Premium Member
Barry
- chookman
- Premium Member
I think that the 2 10kg servos will do the job easily
So there ya have it
looks like you have it sussed ok.
Is the outer end of the flap supported in any way?
- chookman
- Premium Member
Cheers
Barry
It looks like on the original the flaps were in a slotted position when fully extended so presumably they were on rails.
- chookman
- Premium Member
Barry
From what I can deduce from pictures the flap ran on rails (looks like one at each end and two in the middle?). The flap motion appears to rotate about a point low down just inside the fixed part of the nacelle but as you say without detail drawings it is very hard to tell exactly how it all worked..
Then of course there were the Handley Page automatic leading edge slats (which were apparently were usually wired shut in service!) and the radiator leading edge shutter as well as the rear cooling flap. It must have seemed an inordinately complex aircraft at the time.
- chookman
- Premium Member
Remedies are :- 1 reduce that seperation line angle to keep the pivot point as per full size position
2 move the pivot point position and keep that seperation line the same
3 Make the pivot point shift down, on a seperate linkage
The choice I took was #2 [badass]
Yea the end rails will have to be on the same arc as the nacelles, but the good news is that the flap L/E only shifts down 12/14mm on its travel, which will not be too hard to install, butI feelthat the whole flap end may be better if it was also pinned to the rail, again this would look unsightly with the rail sitting out in mid air when the flap is closed. There is no way that I can "dream up" where it can be hidden. :huh:
The Youngman design would be OK, but to incorperate the 2 would be a real brain teaser
So there ya have it, sometimes I feel as if "is it all worth it" :S , but it should be effective
Cheers
B
- Thank you received: 14470
I don't know of anywhere in the U.K that has a Whirly, or a wing, for you to go and look at.
You could try an appeal for info to the holders of the Westland a/c drawings,possibly BAE archives, now, to see if they could assist?
- chookman
- Premium Member
thanks
B
- chookman
- Premium Member
barry
Or maybe you could track down someone who actually maintained or flew them, down there, via the Auz air-force, although they will be getting rather thin on the ground, now!
Barry
Have you seen this drawing?
Item no 80 refers to the "Flap outer track fairing" so the track appeared to run at least partly outside the wing profile.
This drawing shows the flap fully extended and suggests the flap movement was such that the lower part of the movable and fixed elements of the nacelle remained in close proximity throughout the travel hence the circular contact line at that point.
My own guess is the flap moved just on its tracks and the two parts of the nacelle were not hinged or jointed in any way.
Yes it is remarkable that nothing survived particularly as the 5th production Whirlwind was returned to Westland's, civil registered and used a company 'hack' but scrapped in 1947?
Of course the magnesium skin on the rear fuselage would not have survived long term storage particularly well!
If there are any details hopefully the Whirlwind Project should have them!
