Vickers Varsity
22 Jul 2016 21:18 #16 by Ex-Member
Replied by Ex-Member on topic Vickers Varsity
well i have cut another set of fuselage cores and started another set of formers.
these are for Andy's model.
then i did some gluing on the prototype build.
decided to cut alot of the cores away as it is just redundant material, also it has made assembly easier as it gives me exactlocations for the formers.
i need to run a 6mm Depron stringer down the full length when all the formers are done, then i can start sorting out the wing mounts.
we plod on :P
23 Jul 2016 01:59 #17 by Quorneng
Replied by Quorneng on topic Vickers Varsity
Tony
I know Depron is relatively cheap but is there a use for all those substantial cut outs?
25 Jul 2016 17:26 #18 by Ex-Member
The cut outs go in the stores dept for future use on smaller models.
waste not, want not. :P
we now have a kit of Depron parts for a vickers varsity fuselage.
will start the wing parts pile later this week. :)
26 Jul 2016 21:52 #19 by Ex-Member
not got much done today i am afraid.
i have sheeted the fin and half the rudder.
glued the spars to the tailplane and added the trailing edge/hinge points.
not much but it is a step forwards.
wondering about the wing mounting system at the moment.
do i make seperate wing panels and use tubes or do i make a one piece wing and bolt it on, or do i have a fixed center section and have removable outers. arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
27 Jul 2016 08:28 #20 by Ex-Member
[quote="Tony B" post=75947
do i make seperate wing panels and use tubes or do i make a one piece wing and bolt it on, or do i have a fixed center section and have removable outers. ........[/quote]
How big is the wing, Tony?
27 Jul 2016 08:32 #21 by Ex-Member
76" span.
27 Jul 2016 08:47 #22 by Ex-Member
Tony B wrote: 76" span.
It's a bit big for one piece, in my opinion.
27 Jul 2016 08:55 #23 by Klipkopwildlife
Replied by Klipkopwildlife on topic Vickers Varsity
Jup, sounds like a solid centre section with 2 36" wings. That will make the fairings a lot easier to do.
27 Jul 2016 09:17 #24 by Quorneng
Tony
At 76" a one piece wing is just about manageable. It gives the best strength for its weight and assembly at the field is simple but it is likely to require several electrical connections - both power and servos.
There is a lot to be said for a fixed centre section carrying the motors with removable outer panels as virtually all the electrical connections can stay in place, only the aileron servos need to be connected.
My 72" span Hamilcar started out with a fixed centre section and removable wing panels outboard of the engines. Servo connections (2 ailerons, 2 flaps) were very limited for space and had to made as the wing was slid into space. However the biggest drawback was that even the slightest crash tended to create difficult to repair damage the wing joints.
It was later converted to a one piece wing simply bolted onto the fuselage. The electrical connections, power, elevator and rudder (the Rx is in the wing) proved to be easier as the wing to fuselage joint provides much more room.
On my 61" span (but 76" long!) Bombardier with its high aspect ratio wing I also used a one piece 'bolted on' wing largely for structural reasons but by placing a battery in each engine nacelle only elevator and rudder servo connections have to made at the field.
This layout also has the advantage that much of its weight is spread out along the wing which reduces the wing root bending forces in flight. The wing to fuselage joint actually carries very little load.
The choice of wing mounting does rather depend on the positioning and complexity of the "electrics".
27 Jul 2016 09:33 #25 by Ex-Member
battery in nose.
rx in wing.
so maybe one piece and bolt on would be the way to go.
will have a ponder.
thanks
27 Jul 2016 09:38 #26 by Ex-Member
I was thinking more about getting the model to and from the flying field.....a 76" wing would just about fit into the car, but not with the dogs and wife.....so mine would have to break somewhere for transport.
27 Jul 2016 10:52 #27 by Mowerman
Replied by Mowerman on topic Vickers Varsity
Possible solutions -
A bigger car
A large roof box (the type used for skis)
A trailer
Leave the wife and dogs at home (but don't tell her I suggested it)
27 Jul 2016 12:17 #28 by Ex-Member
Mowerman wrote: Possible solutions -
A bigger car
A trailer
Ha ha...none of those are practical and most are uneconomical. I'd still go for a smaller model or one that broke down a bit smaller.
27 Jul 2016 13:33 #29 by one tenor
Replied by one tenor on topic Vickers Varsity
Could a fold back wing work?
27 Jul 2016 13:47 #30 by Ex-Member
well i am looking into a fixed centre section with plug in outers.
ony have to connect the aileron servos up each time then.
bit of designing to do tonight then.
might be able to start building the wing next week.
Time to create page: 1.293 seconds
