- Thank you received: 139
Free Flight Scale
- Mowerman
Although it is only about 40 seconds the flight is really good to watch, very stable and smooth. Fantastic job Monz well done.
- Mike Rolls
- Thank you received: 573
- flight-risk
- New Member
- Thank you received: 11
About to build f/f scale model of the Stewart Headwind.
Wondering if tail-plane areas are allowed to be increased for F.A.I. F/F Scale event.
If memory serves me (questionable!) from years ago a certain % increase was allowable
for tail surfaces, but can see no mention on current F.A.I. site.
The Headwind has about 15% tail-plane area, would this be sufficient for F/F if no increase permitted?
cheers from Australia.
flight-risk wrote: G'day,
Hello flight-risk and welcome to the Forum. When you have a minute, an introduction post would be appreciated on the introduction thread so we all know who we're talking to. It also helps to know the level at which to respond... Either way, you should get a good welcome.
www.aeromodellers.co.uk/forum/thecafe/10...-yourself?start=1515
As for your question, the answer will depend on the competition you are building the model for. If you're not building for competition, then increase the tailplane size as you see fit.
I'm not aware of Australian Scale Rules, but in the UK, any increase in tail size is penalised. The FAI rules tend to mirror those of the UK, which can be found here:
bmfa.org/DesktopModules/Bring2mind/DMX/D...PortalId=0&TabId=219
A 15 % tail is not a major issue, provided you make the section symmetrical or downward lifting. Lifting tails work on duration models, but they reduce the efficiency of the tailplane on scale models as, for stability, they must lift downwards. If you do go for a 15% tailplane, you'll need a C of G further forward than normal. Say 10 - 12%.
Without any further info, that's all the advice I can give at the moment
- flight-risk
- New Member
Yes will be for competition, will go with 15% symmetrical.
NOW for that intro page.......
cheers
gregj
Thinking about it, if you do go for a 15% tail, the forward C of G required will need a lot of decalage (longitudinal dihedral). The issue is then that the angles of the wing and tailplane look wrong when the model is statically judged. A change in wing angle may also effect the model's 'sit' in the air. So we make all the control surfaces moveable. This adds to the scale points statically and allows the elevator to be set up to trim the model for flight.
If you'd like a real time chat on this, hit the Live Chat button to the left of this window. I'll be there for the next hour or so.
Good luck with the model.
- flight-risk
- New Member
one tenor wrote: Would it not be possible to make the wing or tail incidence adjustable with wedges of predetermined size by testing . Slipped into place for flight and out for static judging . Just a thought
Yes, good idea.
Have been "re-honing" my free-flight skills (?) after many years away on sport type models
before having a go at f/f scale, and have used this method to get stable flight.
Should be able to use your idea of removable shims nicely in scale.
Just gotta remember to replace 'em before flying!!
Hope this reads ok, 0200hrs and just finished 12hr ambulance shift.
Cheers
gregj
- Squirrelnet
- Thank you received: 2067
The scale prop is the obvious exception are there any others
- flight-risk
- New Member
Any changes made to main-plane incidence can be made "permanent".
Elevator will be hinged for minor alterations.
Will have down and side-thrust on engine.
Mainly trying for a good flyer on first attempt, fidelity to scale on later models.
Cheers.
Good thinking Gregj, getting it to fly in front of the judges can be the hardest part and is best sorted early! The model you've chosen has a short nose. So, owing to the short moment involved, it'll need a lot more down and side thrust than would be thought normal. The trick will be to keep the prop driver in a correct scale position with the engine at a relatively large angle to the fuselage datum.
