- Thank you received: 10844
Cannot put any pics up as they are on the phone and for some reason it will not connect to the internet
Probably out of credit /?? far more expensive to run than the old one, i suppose i have to pay to use the internet
I will now have to make all new retract doors as the new ones are bigger
Still raining here, thunder storm after thunder storm very violent some of them
- Thank you received: 14473
And try getting your money back if you change sim cards!
Big rip-off!
I appreciate you will be flying from a salt flat but I trust the retract unit (and what it is mounted too) is strong enough to take any rearward loads generated by that long U/C leg.
Hope
But if found a booby i made, the fins on the wing tanks
I made the parallel to the ground with the wings fitted
They are not, the fins should be at the same angle as the wings
Do I leave and who will notice or cut them off and do it properly
Don't think I can leave them I would see them every time I looked at it, bugger
I believe the tank fins are there to damp down any aerodynamic tank vibration that might arise when in place and to make the tank aerodynamically stable when "dropped".
If so, the leg and cylinder hinge-points should be in line, laterally.
As it is, as the leg retracts, the piston ram is being stretched too far, as can be seen in the last photo, where the silver ram cannot reach the blue adjuster on the leg. As the piston cannot come out of the housing, something has to give way!
Will look at it again tomorrow
