1/5 scale Hawker Hurricane.
06 Oct 2017 16:37 #1 by Ex-Member
1/5 scale Hawker Hurricane. was created by Ex-Member
Hello,
Lets start this build off with a few thoughts.
i did fancy a 1/4 scale to go along with my 1/4 scale trent meteor, but storage and transporting will be the issue with a model that size.
so i settled for 1/5th scale, which will give me a wing span of 96", a bit easier to store and transport.
the wing will be split into three parts, two outer sections split from the u/c mounts and a fixed central section.
this will cut down on the wiring that will have to be connected every time you go flying.
well that is the theory anyway.
i plan to use some box aluminium for the wing joiners and to help support the wing in flight.
yes the model will be built mainly from Depron with support from ply, balsa and aluminium where needed.
the aim is to try and keep the weight under 7kg so i can fly her at my club field.
well i will update you more as i plod on with the designing stage.
there is no rush with this project as i need to finish the Lancaster and the trent meteor before i start cutting or building anything.
but i can do the plans, 3d print bits and collect the parts needed.
thanks for watching.
06 Oct 2017 20:36 #2 by Squirrelnet
Replied by Squirrelnet on topic 1/5 scale Hawker Hurricane.
ooh nice project Tony. Always liked the Hurricane too B)
06 Oct 2017 20:47 - 06 Oct 2017 20:50 #3 by Eric
Replied by Eric on topic 1/5 scale Hawker Hurricane.
You might find that carbon tubes are lighter and stronger than ali, have a look here for round, oval, and square tubes of all sizes -
www.carbonfibretubes.co.uk/standard-tubes/
and as they are all a sliding fit within each other, you can do a tapered spar, like a leaf-spring, if you really want to!
Last edit: 06 Oct 2017 20:50 by Eric. Reason: added a comment
06 Oct 2017 20:59 #4 by old fart
Replied by old fart on topic 1/5 scale Hawker Hurricane.
Shame that they don't have any prices. :(
06 Oct 2017 21:07 #5 by Ex-Member
Replied by Ex-Member on topic 1/5 scale Hawker Hurricane.
and the square tubes don't fit tight enough into each other. :(
round tubes look promising though.
will see how much.
Ali is much cheaper i bet. ;)
06 Oct 2017 23:21 #6 by one tenor
Replied by one tenor on topic 1/5 scale Hawker Hurricane.
Great Idea. Prefer the Hurri Back to the Spit. My first proper build I struggled through was aKK Hurricane when i was 9 or 10.With help from my sister in law's nail varnish ( clear ) which she willingly gave to the cause.It was for repairing split formers. ( lots of them ).Half a razor ( 1/4 ? ) is not a good tool in the hands of a 10 yrs old either.
07 Oct 2017 04:37 #7 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic 1/5 scale Hawker Hurricane.
Hi Tony make your own outer tubes from fibre glass, i do now saves me a fortune not having to buy the retail ones for my size of plane, easy to do, i use the round tubes although it should work with square, ill tell you how i do it if interested
07 Oct 2017 07:26 #8 by Ex-Member
THE BLACKBIRD wrote: Hi Tony make your own outer tubes from fibre glass, i do now saves me a fortune not having to buy the retail ones for my size of plane, easy to do, i use the round tubes although it should work with square, ill tell you how i do it if interested
Yes please BB, a thread on how to do it would be very useful. Thanks for the offer... ;) ;) ;)
07 Oct 2017 09:17 #9 by Ex-Member
yes please Tony.
it would be a great help.
thanks
07 Oct 2017 16:35 #10 by boz
Replied by boz on topic 1/5 scale Hawker Hurricane.
a new build. :woohoo: good choice tony, following, boz :)
07 Oct 2017 20:39 #11 by Squirrelnet
How to make glass fibre tubes... yes please B)
08 Oct 2017 00:57 #12 by one tenor
Squirrelnet wrote: How to make glass fibre tubes... yes please B)
And for me too please. I know one way but would like to see your method. If I know my eldest is coming over I'll get him to see if he can bring me some CF offcuts from his work. Without getting into trouble with his boss .He works for Harrison's rods. He joined the firm when he left school when they were just a tackle shop. It would be a shame to lose his job now at 52. Anyway I'll ask him though he keeps saying he's coming and doesn't Doh! If he can bring some I can try my hand at CF tubes.
Cheers John /O.T.
08 Oct 2017 01:43 #13 by one tenor
Tony B wrote: Hello,
Watching but I thought you already had a big (gish ) Hurricane
Time to create page: 1.327 seconds
