Vickers Wellesley
26 Oct 2017 23:15 - 26 Oct 2017 23:16 #1 by Ex-Member
Vickers Wellesley was created by Ex-Member
well the Lancaster refurb is coming on, so it is time to start a dew design.
9th scale the same as the Lancaster.
100" wingspan
Depron and electric usual.
Last edit: 26 Oct 2017 23:16 by Ex-Member.
27 Oct 2017 15:28 - 27 Oct 2017 15:29 #2 by Neddy
Replied by Neddy on topic Vickers Wellesley
That will be impressive!
Some aircraft had the walkways shown by “footprints” painted on the wing. I may have some photos etc. If you need them. I shall be interested to see how you imitate the structure under the fabric covering.
Last edit: 27 Oct 2017 15:29 by Neddy. Reason: Spelling!
27 Oct 2017 16:34 #3 by Ex-Member
Replied by Ex-Member on topic Vickers Wellesley
Neddy, any pictures you have would be very much appreciated.
as for the wings, i am hoping to glue some stringers on the outside of the sheeted wing prior to covering with tissue and silk.
with any luck this will then look a bit like the real thing.
i hope anyway.
28 Oct 2017 14:08 #4 by Neddy
OK - I have the Profile publication for starters and I wonder if it might be best if I scan the pictures etc. and send them to you via email to preserve the quality. As regards the "framework" from what I have seen on old aircraft it was fairly subtle so what might be easier and more effective would be to run lengths of thread of a suitable thickness along the lines of the framework which when dry you could and a little to give the impression of varying prominence.. However just an idea - try it on a peice of scrap sheet first and cover it with just tissue given how much silk can cost these days.
This for a taster...... (snigger snigger)
Thanks: Phil Wood, Klipkopwildlife, Ex-Member, boz, Squirrelnet
28 Oct 2017 15:44 #5 by Ex-Member
Just what i am looking for young sir.
arden48@gmail.com
feel free to send all you can on this interesting aircraft.
thank you so much
28 Oct 2017 15:46 #6 by Ex-Member
28 Oct 2017 16:22 #7 by Neddy
Yes boss! "young" ???? You are so kind. May be a day or two - hope that is OK.
31 Oct 2017 20:56 - 31 Oct 2017 20:59 #8 by Quorneng
Replied by Quorneng on topic Vickers Wellesley
You may have to go easy on making the 'geodetic' visible.
This picture of one under construction clearly shows that stringers were added to the rear fuselage to lift the fabric clear of the under lying structure.
www.shu-aero.com/AeroPhotos_Shu_Aero/Air..._construction_01.jpg
I have a suspicion that the same sort of thing was done on the wing, at least as far as the spar,
None of the period photos I have found seem to show any trace of the geodetic structure on the wing fabric surface.
Link
Last edit: 31 Oct 2017 20:59 by Quorneng.
31 Oct 2017 21:29 #9 by Squirrelnet
Replied by Squirrelnet on topic Vickers Wellesley
At risk of publicising other sites :whistle:
The full set of Profile publications including the Wellesey are available to download as PDFs from Hip Pocket Aeronautics :)
www.hippocketaeronautics.com/hpa_plans/
Thanks: Klipkopwildlife, Ex-Member, boz
01 Nov 2017 22:03 #10 by Neddy
I am sure I have photos showing the structure through the fabric but yes it is not pronounced. The fabric was influenced by the weather and humidity etc. so it would depend on when and where pictures were taken. Certainly the Wellington showed its “bones”. I will see what I can find shortly.
Thanks: Ex-Member, boz
01 Nov 2017 22:57 #11 by Ex-Member
Just ordered a little booklet on this aircraft, might give me some details.
finished the fuselage formers, could almost start building now. hmmmmmmmm
time to work on some wings.
Tony (drawing mad) B
02 Nov 2017 06:13 #12 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Vickers Wellesley
How about flying the Trent Meteor, or TSR2, op the
02 Nov 2017 07:41 #13 by Ex-Member
TSR2 has been scrapped.
Trent meteor is the next on to be finished after the Lancaster, even though i have no where to fly it as it is too big to be flown at my club.
Tony (loves building more than flying) B
04 Nov 2017 19:30 #14 by Ex-Member
As i am sooooo fed up with rivets at the moment i have taken a couple of days off.
Another day tomorrow i hope, then back to the rivets on the Lancaster.
05 Nov 2017 19:50 #15 by Ex-Member
outer wing panel cores cut.
fin and rudder under construction.
Jogging on with this one, though it will slow down once the details start.
Time to create page: 1.344 seconds
