Avro Shackleton mk3 phase 2
18 Mar 2018 18:19 #1 by Ex-Member
Avro Shackleton mk3 phase 2 was created by Ex-Member
Well here we go.
afer the failed previose atemp i have decided to try again.
cut the cabin floor from 6mm ply and 3d printed a few cabin formers.
then i designed and printed out thee main flight instrument panel and fitted it to the relative former.
next came the pilot, co pilot and their seats, plus the throttles.
i need to finish painting the pilots before i can glue them in.
18 Mar 2018 18:21 #2 by Ex-Member
Replied by Ex-Member on topic Avro Shackleton mk3 phase 2
The flight engineers station was the next one to be designed and printed.
then the signallers station was done and glued in place.
this was quickly followed by the navigator and tactical navigators stations.
18 Mar 2018 18:24 #3 by Ex-Member
The first of the crew have been printed and glued to their seats. seats are not fitted yet as i need to finish the crews faces first.
but they will all fit here...i hope.
so this is as far as i have got to date, more to come as i design and print the relative parts needed.
Thank you
18 Mar 2018 18:45 #4 by Squirrelnet
Replied by Squirrelnet on topic Avro Shackleton mk3 phase 2
Looking very good Tony, cockpit looks fantastic. I look forward to watching this one progress all the way to flying shots ;)
19 Mar 2018 14:51 #5 by one tenor
Replied by one tenor on topic Avro Shackleton mk3 phase 2
Terrific job sir
24 Mar 2018 19:42 - 24 Mar 2018 19:50 #6 by Ex-Member
Fuselage joining tube glued to the underside of the cabin.
the rear section of the fuselage will be built round another tube so that i can just slide it inplace and do up two bolts to hold it together.
The wiring will be run through this section of the fuselage as i will be able to access it all through the open bomb bay doors.
Last edit: 24 Mar 2018 19:50 by Ex-Member.
27 Mar 2018 19:50 #7 by Ex-Member
well i have finished printing and fitting the underformers and can now so a little bit of eexternal sheeting.
the next big job is to design all the bomb doors and get them working, not sure on how to hinge them yet though.
then i expect i will be back on designing internal fittings again.
we plod on
27 Mar 2018 20:30 #8 by Squirrelnet
Superb build Tony...looks like a tube train at the moment :P ;) but looking forward to watching this one take shape B)
Thanks: Ex-Member, Flytilbroke
30 Mar 2018 17:59 #9 by Ex-Member
Started the nose construction.
th front u/c will be mounted to ply formers that will be glued to a section aluminium box, this will then be fitted into the largerr box that runs under the cabin.
so the nose should be non structual... i hope.
31 Mar 2018 18:58 - 31 Mar 2018 19:00 #10 by Ex-Member
Today i have made the front u/c mount.
it is made from 6mm ply and is glued and bolted to to some 20mm square box.
the box then slides inside the 25mm box that runs under the cabin floor and will be held in place by two bolts.
i also drew up and printe off the frame work for the front gear doors.
this is also gluing in place.
slow old day today.
Last edit: 31 Mar 2018 19:00 by Ex-Member.
31 Mar 2018 21:58 #11 by one tenor
Slow day my a@@ [badass]
01 Apr 2018 18:41 #12 by Ex-Member
nose section and u/c mount glued and bolted on.
we can now start adding some internal details before i skin it.
02 Apr 2018 19:35 #13 by Ex-Member
started adding floors and walls, it don't arf firm up the nose. ;)
13 Apr 2018 19:57 #14 by Ex-Member
started the rear section of the fuselage.
this is removable to aid transport and storage, just hope it works.
Time to create page: 1.219 seconds
