Miles Sparrowjet
12 Feb 2020 18:30 - 12 Feb 2020 18:38 #16
It can be done with two 30 mm EDFs.
32" span and 246 g with a 950 mAh 2s but it is rather an extreme construction exercise being Depron and tissue!
It flies nicely but duration is limited to 4 minutes max. Days like this don't happen often in the UK!
With its tiny EDFs screaming away at 30,000+ rpm it sounds about right too. In full ground effect the glide landing is a non event.
Last edit: 12 Feb 2020 18:38 by Quorneng.
- Specialbuilder
- Thank you received: 163
12 Feb 2020 19:21 #17
by Specialbuilder
Replied by Specialbuilder on topic Been Flying
Well, that's promising. But I haven't used tissue since I was a kid. What do you glue it on with?
I suppose if you can do it with Canberra, I can do it with the Sparrowjet. But I suppose I should learn to fly confidently first! I have a large conventional trainer, a Pietenpol, a Spitfire, a Skystreak 32 in foam, a shoulder wing sports IC job and a glider electric conversion, so I probably have enough to be going on with! But I do want to do the Miles eventually.
Martin
Martin
13 Feb 2020 17:08 - 13 Feb 2020 17:12 #18
Replied by Klipkopwildlife on topic Miles Sparrowjet
This could be a build from a newer member and includes the discussion.
Last edit: 13 Feb 2020 17:12 by Klipkopwildlife.
Time to create page: 1.429 seconds
