- Thank you received: 9
Fuel proofer?
- Del Piero
- Junior Member
What are you guys using as fuel proofer on diesel powered models please?
I have tried a couple of varnishes, but they always seem to bubble up.
Many thanks,
Del Piero.
It's only the either that's aggressive and that evaporates like mad! As long as the model is protected against the soaking in oil it will surely get you'll be ok.
Oh btw enamel is ok over dope if your painting some decoration but don't try it the other way round!!!
hope that helps...
I think I'm the only one here that uses diesels? dying breed!
- Del Piero
- Junior Member
Del Piero.
Depending on how it was applied, oils can seep in between the fibres. Even if it cannot penetrate the dye layer, it gets trapped in the weave, and very soon looks mucky.
- Del Piero
- Junior Member
It really needs something, as it soon looks very messy.
I've tried Ronseal silk outdoor varnish and Wilko outdoor varnish.
On both models, this has bubbled up, particularly around the engine bay and undercarriage, hence my enquiry.
Del Pero.
Even polyurethane paints suffer over time hence the importance of removing all traces of nitro glow fuel after flying. Not easy if the covering itself is porous.
Sorry, should have gone back to the original post.
Just as well its only at 2% concentration in the fuel.
- Flytilbroke
- Thank you received: 1978
I have used dope and some times polyurethane varnish as proofer.
