- Thank you received: 2
Flight box battery
- bishbosh77
- New Member
06 Feb 2024 17:07 #1
by bishbosh77
Flight box battery was created by bishbosh77
Hello
well my first post on here so hopefully not a daft question))
I have just got a flight box and looking for recommendations for a battery that will power a starter and fuel pump .
any recommendations appreciated.
I have seen a Duracell DR7-12 7ah at a reasonable price but not sure if it’s suttable
regards
regards
- Thank you received: 14309
06 Feb 2024 21:10 - 06 Feb 2024 21:19 #2
Replied by Eric on topic Flight box battery
You don't say how big the space is for the battery, in the box.
For most people, a motorbike battery will suffice 12v and 7 amps will last all day, generally.
You will also want a couple of screwdrivers of different head styles and widths, a glow-plug spanner, spare plugs, and a small spanner - an adjustable one is fine - for undoing prop nuts, and spare props, because you are bound to break a few!
As you are asking a pretty basic question, I assume you haven't flown r/c models before, so I strongly recommend that you join a club near you, and learn properly. It will save a lot of heartache and broken models!
You will also need insurance, and a CAA identity number. The club will probably sort that out for you.
Then you will find a spray bottle of degreaser, kitchen tissues, and the like, for cleaning your models after flying - will be useful..
The DR7 you mention only has very small 'spade' connectors, so would be very fiddly to use on the field.
Last edit: 06 Feb 2024 21:19 by Eric. Reason: typo
07 Feb 2024 07:46 #3
Replied by Klipkopwildlife on topic Flight box battery
Most commercial flight boxes are sized to take the 12volt 7Ah alarm system battery (it's a leak proof Gel cel) They're very sensitive to over voltage and over current charging, a standard car charger will destroy it in fairly short order! Also, always recharge it immediately you return from the field, leaving it in a discharged state will also seriously shorten its life.
As an aside, since the advent of the new small capacity UPS which use this same battery (1 or 2) it's become impossible to find any batteries of decent quality. (Locally anyway)
A Lipo equivalent is available at an eye watering price but not to be recommended unless you have a proper charger.
Thanks: Eric, Quorneng, THE BLACKBIRD
07 Feb 2024 07:47 #4
There's no such thing as a daft question, only stupid answers!
Thanks: bishbosh77
07 Feb 2024 12:03 #5
Time to create page: 0.212 seconds
