Glueing sheeting?
  • Dean M
31 May 2012 04:27 #1 by Dean M
Glueing sheeting? was created by Dean M
The fuselage of the deagostini spitfire I am building is fully sheeted in balsa. I am finding it a real slow process due to using normal white wood glue, I glue a section on then tape and clamp it down, I then have to wait a couple of hours for it to dry before I can do anything more to it.
I did try some evostick contact adhesive but the missus wasn't pleased at me stinking the whole house out!!!!! :lol:
Is there any good, quicker, non smelly ways of sheeting the fuse? Or do I go into the garage and use the evostick?
Dean
I nearly choked on my latte.
31 May 2012 04:30 #2 by Eric
Replied by Eric on topic Re: Glueing sheeting?
Use the pva, but with dots of instant superglue to tack the bits in place.
31 May 2012 04:35 #3 by Ex-Member
Replied by Ex-Member on topic Re: Glueing sheeting?
i use super glue.
stick the edge.
then run the glue down the formers and hold the balsa in place for 20 secs.
  • Dean M
31 May 2012 04:36 #4 by Dean M
Replied by Dean M on topic Re: Glueing sheeting?
Cheers Eric.
So would I wood glue the middle part and put spots of super glue on the edges to keep it held down until the wood glue drys?
Dean
  • Dean M
31 May 2012 04:40 #5 by Dean M
So do you just superglue the whole lot then tony?
Hopefully this should speed up the build!
dean
31 May 2012 04:45 #6 by Ex-Member
i do yes.
depends how flexible the balsa is.
if you stick a bit and then pull it away from the fuselage enough to dribble the glue down the formers so it runs down the wood.
you can then just hold the wood flat against the formers and bobs ya uncle.
31 May 2012 12:37 #7 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Glueing sheeting?
PVA or Aliphatic glues are slightly flexible, which is why they are preferred by some people. Acrocyanoacrilates are very brittle. What Eric suggests is considered to be the best way, you get speed, and joint reliability.
  • Dean M
31 May 2012 14:31 #8 by Dean M
Thanks every one, hopefully I will speed up a bit now B)
Dean
  • Sangoma
31 May 2012 20:47 #9 by Sangoma
Replied by Sangoma on topic Re: Glueing sheeting?
I would be reluctant to onlt use CA, as said it is brittle, and comes apart in a high G arrival. The main problem then is that you need to take apart a lot more of the undamaged part to reglue the joints.
I recently dropped a helicopter onto a completed wing that had been stuck with CA, the wood didn't break, but a huge amount of joints need redoing. Same thing on the webbit, lots of the fuselage come undone without much damage to the wood.
It is really more a time planning problem, organising the assembly so that there is always something else to do or glue.
I like gorilla glue on sheeting, as it foams it forms a fillet, and spreads the load a bit onto a wider area of sheeting, and as stated it has a bit of give in it
Time to create page: 0.557 seconds
