Split flaps
  • Dean M
22 Feb 2013 01:51 #1 by Dean M
Split flaps was created by Dean M
On my TN B-17 I want to fit split flaps, I have bought the cnc pack so have all the ribs cut out.
This is a picture of the ribs on the plan, will it be better to cut the ribs for the split flap before I have made a skeleton wing? what is the best approach for this? should I look at photos of B-17s then mark out the flap on the plan?
I nearly choked on my latte.
22 Feb 2013 01:54 #2 by Ex-Member
Replied by Ex-Member on topic Split flaps
i would draw the flap on the plans and cut the ribs before building the wing.
22 Feb 2013 02:05 - 22 Feb 2013 02:08 #3 by Eric
Replied by Eric on topic Split flaps
Didn't know a B17 had a reflex wing section! That's for flying wings, to generate pitch stability. A flap on a reflex works like down elevator!
See en.wikipedia.org/wiki/Flap_%28aircraft%29 and scroll down about halfway to see different flap config's.
You would need to cut the flap out of each rib before you build the wing.
Last edit: 22 Feb 2013 02:08 by Eric.
Thanks: Dean M
  • alan cantwell
  • alan cantwell's Avatar
  • Inactivated User
  • Inactivated User
22 Feb 2013 02:08 #4 by alan cantwell
Replied by alan cantwell on topic Split flaps
or is it just the plan bent up? all mods to any kit of parts should be done before gluing together, you will never do it after,
Thanks: Dean M
  • Dean M
22 Feb 2013 02:21 #5 by Dean M
Replied by Dean M on topic Split flaps
Thank you everyone.
I will work out what will look right then sketch it onto the plans and see what the opinion is on here!!
I had the plans copied and rolled them up what you can't see in the photo is my trotter holding the plan up making it all look a bit wibbly wobbly.
22 Feb 2013 12:02 #6 by Phil Wood
Replied by Phil Wood on topic Split flaps
Dean M wrote: On my TN B-17 I want to fit split flaps, I have bought the cnc pack so have all the ribs cut out.
The picture is a bit confusing Dean ... look at the black line to the right, ... it's supposed to be straight.... you've given us an optical illusion mate .... trust you, send it to Garry & he might get something almost straight for once. :lol: :lol: :lol:
Time to create page: 0.159 seconds
