- Thank you received: 326
Engine mounting
- Dean M
25 Nov 2013 11:03 #1
by Dean M
I nearly choked on my latte.
Engine mounting was created by Dean M
I'm not sure if I have asked this before.
On my Kavalier somehow I managed to mount the engine a lot further forward than what is on the plans! Will this have any detrimental effects?
I need to make a balsa cowl which I was going to do after I had maidened it but the firewall will be covered in lovely smelly greasy fuel making it a lot harder to glue bits to the firewall. So ideally want to sort the cowl before I fly it.
25 Nov 2013 18:21 #2
by Garry Pollard
Replied by Garry Pollard on topic Engine mounting
Mounting the engine further forward will affect the Cof G Dean, but will have no detrimental effect on the flying.
Have you thought of making a cowl that can be removed and replaced, or is this not possible. As you rightly say, it WILL be covered in goo, and difficult to glue to
- Thank you received: 14305
25 Nov 2013 18:33 #3
Replied by Eric on topic Engine mounting
As Garry said - the engine is about the heaviest piece of the model, so all you will do is move the c of g point further forward. You can accommodate this by either having less lead n the nose, or putting the receiver battery further back!
Regarding the cowl. Put mounting blocks onto the firewall, seal it all up with fuel-proofer, and then screw the cowl onto the blocks when you are ready! No sticking trouble involved, and it makes it easier to get it off again when the fuel pipe perishes, or a back-case screw falls out!
Thanks: The Beard, Dean M
26 Nov 2013 12:52 #4
Replied by Quorneng on topic Engine mounting
"but will have no detrimental effect on the flying."
Unless you add that much side area forward of the CofG as to effect the lateral stability.
Thanks: Dean M
26 Nov 2013 21:47 #5
There's always that!
You can always cheat, and add a sub-fin, or make a strake a bit bigger!
Time to create page: 0.287 seconds
