- Forum
- Forum Categories
- Construction Techniques & Aeromodelling Materials.
- Depron as a Building Material
i am looking for a cheap supplier of depron and some advice on using it.
thank you
Tony Bennett.
- Monz
Buy from here: www.depron.co.uk/ They're the cheapest that I've found, and deliver in two/three days.
The white stuff comes in slightly smaller sheets, is a bit more brittle and takes a bit longer to form.
The grey stuff comes in a sheet that's 20% larger for the same price. Bit less brittle and easier to form.
Buy a split box of half 3mm and half 6mm, I use 6mm for all the insides and 3mm for skinning.
You can buy a cheap gorilla glue type PU adhesive from your local DIY. I use that for most of the structure, and then UHU Por for skinning.
On my Bucc, the only timber is 20mm pine dowel for the spars, balsa leading and trailing edges and balsa leading edges on the control surfaces. I used Poly-C and 25g/m² cloth to cover it.
Anything else just shout and I'll help where I can
fancy knocking up a small funfly type machine or a rubber FF model.
I am not sure you have to 'commit' to using Depron. Unless you are going to build something truly enormous it is so cheap compared to balsa you can play with it as much as you like. In general however the bigger you go the less of an advantage Depron has and the more other, more expensive, materials have to be used as well.
To be exact there are two types of Depron, 'normal' and 'aero'. Both are made of the same type of plastic. The colour itself, white or grey, is not a significant factor to its mechanical properties.
As Monz says Normal is more rigid but heavier. Its 'bubble' internal structure has a denser surface skin.
Aero has a finer bubble structure is more flexible, softer and about 25% lighter. It has no skin.
The aero type is on the left. They are both 20 mm squares of 6 mm thick.
To give an idea of cost a 1250mm x 800mm sheet of 3mm grey Normal Depron at Steve Webb models is £2.99 but of course at that size you have to pick it up.
A tube of UHU POR glue on the other hand is £3.50!
- Phil Wood
- Inactivated User
Tony, is this for your possible business venture? most firms will happily send out substantial samples if you convince them it's for a serious business.Tony B wrote: Dear people.
thank you
Tony Bennett.
I was seriously looking into EPP models & one firm sent me a bloody great block that would have retailed at over £60 ..... but I wasn't joking, I meant it as a business & possibly still do.
I can advise you on some of the chemical aspects of Depron, you know about science being my field.... I can't advise further than that because I don't know what you're cooking up.
I hope it's good mate.
want to build a couple of sports models first.
Depron is much lighter (and weaker) than balsa so I am sure you could use it for the parts of an IC powered plane that have the lowest stresses.
I expect the structure would have to go hardwood or ply, then balsa and finally Depron.
I think polystyrene is ok with diesel fuel but I believe methanol/nitro does soften the surface.
White is slightly more expensive as the sheets are a bit smaller for the same price.
Garry Pollard
Administrator
nice to have you here.
welcome.
tony.
- Thank you received: 10722
I use scalpels number 4 handles and no.26 blades they are far stronger than the no. 11 blades
- Forum
- Forum Categories
