Antonov AN 124 Rusian
08 Nov 2019 19:00 - 08 Nov 2019 19:01 #151 by Quorneng
Replied by Quorneng on topic Antonov AN 124 Rusian
After much cogitation (and some reasonable weather) I stripped out and folded down the seats of my car to see if the full AN124 fuselage duct taped together would fit into the Clio Estate with the tail plane and fin attached. With its nose removed It does - just!
This was a relief as it will result in a significant tail weight saving from it all being permanently built into the fuselage.
Pics to follow as it happens. ;)
Last edit: 08 Nov 2019 19:01 by Quorneng.
Thanks: Eric, crash happy
11 Nov 2019 21:27 #152 by Quorneng
Having constructed but, certainly not finished, the 'construction' part of the whole air frame the time has come to see if the thrust is likely to be anywhere near enough to fly at:woohoo: its target weight of 1.2 kgs. I do have a plan B but lets not even consider it!
For CofG reasons the battery/s (?) will have to be well forward but hopefully still part of the wing structure.
To keep the ESC to battery distance to a minimum will mean the motor to ESC wires will be long, indeed for the outboard motors they will close to 900 mm long! :woohoo:
Given the lengths required lacquered 0.71 mm magnet wire will be used to save weight and the first bench test will use 900 mm wires as it represents the worst case scenario.
Fortunately the 'Little Bee' ESCs are tiny.
No BEC so a separate UBEC is required which is actually slightly larger than the ESC!
Only a quick test run so far. The Wattmeter showed just 4.95 A on a not fully charged 4s.
It makes a very realistic noise and certainly seems to pull pretty hard. I shall have to find a way to measure it reasonably accurately.
I am looking for at least 5 oz (140 g) thrust from each nacelle but even that would be pretty marginal.
12 Nov 2019 10:35 #153 by Quorneng
With the house quiet this morning I made a video of the first test of a complete nacelle.
Surprisingly quiet but to be fair 'hand held' does eliminate any resonance which the complete air frame certainly will. It should sound quite impressive with all four going.
Still got to work out how best to measure the thrust. If it is too feeble then it is on to 'plan B' before going any further.;)
Thanks: crash happy
  • crash happy's Avatar
12 Nov 2019 10:49 - 12 Nov 2019 11:21 #154 by crash happy
Replied by crash happy on topic Antonov AN 124 Rusian
That really does sound very good. With all four running it should be pretty impressive ! :woohoo: Any more thoughts on how you are going to "launch" it ?
PS. If you can't find some paperwork that was on your desk It got blown down the back ! :lol:
Last edit: 12 Nov 2019 11:21 by crash happy. Reason: Added comment
12 Nov 2019 15:07 #155 by Quorneng
Crash
The thing that went down behind the desk was actually an envelope that contained my old cut up driving licence that I was going to send to the DVLC until I noticed it required a stamp! So I think it can safely remain behind the desk for the time being. ;)
A bit more progress, a thrust test stand.
It will push down on a set of kitchen scales.
At the moment the exhaust is exactly the FSA (Fan Swept Area) whereas the inlet is 1.16 times it.
Conventional 'EDF' wisdom suggest maximum thrust is obtained with an exhaust at about 85% the FSA and peps have actual test results to prove it.
However this is for multi blade EDF fans and to my mind mostly with questionable inlet ducts. Few actually measure the EDF in free air probably because they don't really want to know how much thrust the ducts actually loose!
I can make a 'pear' shaped tail cone that could reduce the exhaust area so out of curiosity I might take the opportunity to test the theory but I will be amazed if it make a measurable difference.
Finally a bit of a disaster.
I dropped one of the pylon motor mounts onto a hard floor. :( It had the motor attached so the weight did some damage on what is about the most highly stressed part. Still its only another 2 hours 24 mins to print a replacement but it will at least be exactly the same. :P
12 Nov 2019 16:02 #156 by crash happy
Neat idea with the test stand ! If the scales are going on the base, shouldn't the motor be the other way up ?
12 Nov 2019 16:19 - 12 Nov 2019 16:24 #157 by paul d
Replied by paul d on topic Antonov AN 124 Rusian
Nice work indeed! Question: Does that truly qualify as a "ducted fan"? not sure when a cowl becomes a duct.....
I suppose it could be described as a non rotating "kort nozzle"
Last edit: 12 Nov 2019 16:24 by paul d.
12 Nov 2019 17:26 #158 by Klipkopwildlife
Replied by Klipkopwildlife on topic Antonov AN 124 Rusian
Crash, the way I see it, the whole thing sits on the scales, foot included, then you zero the scales and fire up the motor, whatever reading you get is the thrust.
Thanks: crash happy
12 Nov 2019 17:50 #159 by crash happy
"Doh", yes of course ! Chalk that up as a blonde moment then shall we ! :oops:
13 Nov 2019 00:10 #160 by Quorneng
To my great relief the nacelle works a bit better than I expected. It delivers almost exactly 8 oz of thrust. :)
This means I could be looking at a thrust to weight of about 80% which would greatly improve the chances of it flying properly. ;)
I then produced this rather exotic shaped exhaust tail cone.
Its bulge reduces the exhaust area to 95% of the FSA.
To my amazement with it installed the thrust went up to 8.3 oz. :ohmy:
I then removed it and did two tests, first with the cone removed altogether - 7.9 oz, then with the simple 'FSA' cone - 7.9 oz again. I then put the bulged cone back on - thrust back to 8.3 oz. :P
All the test were done on the same battery without any recharge.
It appears I have to eat humble pie! :oops: but 0.3 oz (3.75%) extra thrust for nothing is worth having.
13 Nov 2019 07:31 #161 by crash happy
That's brilliant ! Just goes to show a little bit of experimentation can often be worthwhile, bearing in mind that's 0.3 X 4 ! :cheer:
13 Nov 2019 17:06 #162 by Klipkopwildlife
It's not for nothing that the F1 guys will spend days in the wind tunnel evaluating the effect of a 10mm tab!
Thanks: crash happy
14 Nov 2019 00:41 - 14 Nov 2019 00:43 #163 by Quorneng
Took most of the day but the left hand motors and nacelles now installed on the inner section of the LH wing.
The motor wires run just behind the spar web.
The ESCs are just temporarily placed for testing.
The motor wires are soldered directly onto the ESCs so you are faced with having to re solder a pair if the motor goes the wrong way. ;)
I actually did it on 3 occasions and each time it was wrong. :( Given its a 50/50 chance of being right Sod's law was obviously working well! :woohoo:
Last edit: 14 Nov 2019 00:43 by Quorneng.
Thanks: Klipkopwildlife, Ralpharr2001, crash happy
14 Nov 2019 14:59 #164 by Quorneng
It was a bit late last night to actually run them ;) so a video of this morning's test using a 4s.
Its starting to get quite loud!
The throttle ranges of the drone "BL Heli" ESCs are not particularly well matched and they beep periodically as well as if rearming although once running they work ok.
14 Nov 2019 15:09 #165 by paul d
Well they've certainly got some puff! saw the clothes hanging on the door!
Even though it's well known I'm not a electric fan ( no pun) they did sound good, with a more linear throttle they could be mistaken for jets.
Time to create page: 2.987 seconds
