Acrowot electric foamy
  • The Beard
14 Dec 2014 14:57 - 14 Dec 2014 16:10 #1 by The Beard
Acrowot electric foamy was created by The Beard
On Friday decided I needed 2 models at the field and purchased one of these .easiest thing to put together and itll take longer to fit the decals so it comes with motor ESC and servos installed so will soon be ready for maiden
Last edit: 14 Dec 2014 16:10 by .
14 Dec 2014 15:58 #2 by Mowerman
Replied by Mowerman on topic Acrowot electric foamy
Check the model very carefully for warps, a member of my club had two and totalled both due (he insists) to warped wings cause by the packing.
14 Dec 2014 16:14 #3 by
Replied by on topic Acrowot electric foamy
Must second Mowerman s concern Stephen, as one was totalled at one of my flying sites only a week or so ago. The same concern was expressed, and the pilot was not a novice flyer. However, he did admit to not checking for warps. :( :( :(
  • The Beard
23 Dec 2014 12:46 - 23 Dec 2014 16:04 #4 by The Beard
Replied by The Beard on topic Acrowot electric foamy
thanks iads well firstly simplest build ever such a doddle its all looking straight but when i get home ill have a good look and do some photos also,Its ready for its maiden looking good
Last edit: 23 Dec 2014 16:04 by .
  • The Beard
23 Dec 2014 22:20 #5 by The Beard
photos not posting
  • The Beard
24 Dec 2014 23:00 #6 by The Beard
foamy acrowot
  • The Beard
25 Dec 2014 10:05 #7 by The Beard
[img]http://[/img]
File Attachment:
[td]
Warning: Spoiler!
[/td]
[td][/td]
[tr]
[td][/td]
[td][/td]
[/tr]
  • The Beard
25 Dec 2014 10:06 #8 by The Beard
wow done it on photobucket
  • The Beard
26 Dec 2014 15:38 #9 by The Beard
I maidened the Acrowot today and no trimming needed the ailerons are a bit lively but its superb to fly
26 Dec 2014 20:28 #10 by
If you are pleased with it mate, that is all that matters . Well done
  • The Beard
26 Dec 2014 20:31 #11 by The Beard
your right Garry
  • The Beard
28 Jan 2015 17:38 #12 by The Beard
well the acrowot isnt playing ball Ive been given some ideas to try but throttle warning keeps going and no throttle so searching in vain at the moment
  • The Beard
28 Jan 2015 19:04 #13 by The Beard
Blue is the man altered throttle from 82 to 100 and its all ok but why did it not do this first time .Of course I used a receiver from a ic model and it still had that previous models settings Ive also reduced ailerons and elevator to calm it down thanks Blue
28 Jan 2015 19:19 #14 by Eric
Replied by Eric on topic Acrowot electric foamy
Beardy - for the acrowot, put in about 30% expo on ele and ails, and keep plenty of control movement, then you have the 'soft' control around the centres, but can really throw the plane about, once you have it's measure.
It's a very forgiving model that won't 'bite', no matter what daft controls you apply. With it being so light, most times if you hit the floor a bit firmer than you intended, it will bounce - but they do tend to forget to take the undercarriage with them, unless you have replaced the weak plastic bolts, and strengthened the ply plate.
  • The Beard
29 Jan 2015 09:05 #15 by The Beard
im not an expo person dont like the vagueness but your right on my first landing it left the uc behind including a chunk of fuselage which glued back well.
Time to create page: 0.187 seconds
