Mixing Lipos.
23 Apr 2015 21:07 #1
by Garry Pollard
Mixing Lipos. was created by Garry Pollard
Can one of my electric flight friends refresh my failing memory.
I remember reading a couple of years ago on the RCME forum the reason why if say the model is a 10 s powered unit it is advisable to use 2 matched 5 s lipos. Should a 4s 5000mah and a 6s 5000mah be used, what would be the result, and what if any would be the damage caused to the lipos .
23 Apr 2015 21:51 #2
Replied by Quorneng on topic Mixing Lipos.
When coupled in series a 4s and a 6s is a 10s providing their capacity and C rating are the same. Indeed you could make up a 10s using any combination of cells (even 10x1s!) providing they are all the same capacity.
The main issue with unequal cell count batteries is charging them. The only way they could be charged from a single charger would be as a 10s but you would have to make sure the balance leads and plugs were organised correctly.
HobbyKing sell a 7s LiPo that has a 4 and 3 JST balance plugs. It caused quite a bit of confusion until they supplied a 4 + 3 into 7 adapter!
Thanks: Garry Pollard
23 Apr 2015 22:06 #3
Replied by Eric on topic Mixing Lipos.
As Simon said.
But do not try using a 5000 and a 3000 pack in either series or parallel. You will end up with a severely depleted and possibly blown smaller pack.
23 Apr 2015 22:51 - 23 Apr 2015 22:53 #4
by Garry Pollard
Replied by Garry Pollard on topic Mixing Lipos.
Thanks lads, however may have a further problem. Both the 6 s and 4 s packs are 5000 mah but I am sure that the 4s are rated at 20c and the 6s are rated 30c if these are coupled to provide the 10 s requirement what would be the net result of this . The packs would be recharged as separate lipos Simon, not as a 10 s pack . Its now the different c rating that is causing me concern .
I did see the discussion re the HK 7 s packs and the confusion that it caused
Last edit: 23 Apr 2015 22:53 by Garry Pollard.
23 Apr 2015 23:18 #5
If your discharge load is LESS than the smaller pack can deliver, there will be no problem.
The C rating is merely the max rate of charge/discharge for the pack. (although if you regularly charge them like that, they won't last long - as you probably already know!)
If your discharge rate is close to or greater than the smaller pack, then you will be in trouble!
Time to create page: 0.252 seconds
