Dynam ARTF foamy Texan
  • The Beard
13 Jan 2016 21:03 #1 by The Beard
Dynam ARTF foamy Texan was created by The Beard
ordered this from Nitrotek and had to wait for it at depot first appearence was looking good com,es complete with receiver and controller Made In China.you have to figure most of it out for yourself but there are vague instructions on assembly but you have to find where the top comes off for access inside and where the battery goes so not a kit suitable for beginners at all as you need plenty of experience to figure it all out
  • The Beard
13 Jan 2016 21:04 #2 by The Beard
Replied by The Beard on topic Dynam ARTF foamy Texan
Oh dear ive gone dizzy .comes with 2200 battery and retracts and fully electrified.
  • The Beard
13 Jan 2016 21:05 #3 by The Beard
If Im happy with this kit then ill get there Hurricane
13 Jan 2016 21:16 #4 by Garry Pollard
Replied by Garry Pollard on topic Dynam ARTF foamy Texan
Any chance of another picture Stephen, so we can be sure of what you have got :woohoo: :woohoo:
13 Jan 2016 23:34 #5 by Eric
Replied by Eric on topic Dynam ARTF foamy Texan
Is it a Policeman???
No - it's the fuzz! [badass]
Thanks: The Beard
  • The Beard
15 Jan 2016 20:00 #6 by The Beard
the models is going together very easily so far and there isnt a lot left to do but the 2 pilots are a bit strange to me
  • The Beard
15 Jan 2016 20:03 #7 by The Beard
the wings are on and they come in 3 pieces the centre section has the retracts.4 screws hold it on the fuselage and 2 screws hold the wings to the centre section
  • The Beard
15 Jan 2016 20:05 #8 by The Beard
dummy Engine
  • The Beard
15 Jan 2016 20:10 - 15 Jan 2016 20:23 #9 by The Beard
the only problem ive come across is rather major,I dont think the receiver and controller communicate .There is no instruction to bind and I canrt see anything that looks like it should be bound and there is no instruction or mention of the receiver.Plug the battery in and all you get is steady alarm and the receiver has a flashing red light.Ive fitted Futaba receiver and it is working perfectly on my dutaba controller.One of the rtracts was stuck but with a little pull it came down and both work fine now
Last edit: 15 Jan 2016 20:23 by Garry Pollard.
  • The Beard
15 Jan 2016 20:13 #10 by The Beard
Plenty of room there.I need to decide on how to wire wing lights up the wires dont have plugs connected.Im choosing different pilots.to do list is fit pilots glue canopy on connect rudder and elevator push rods decals and prop and thats about it
15 Jan 2016 20:19 #11 by Quorneng
Replied by Quorneng on topic Dynam ARTF foamy Texan
I would guess one is a present day pilot - Tom Cruise? ;) the other is 'period' - Chuck Yeager? ;)
Thanks: The Beard
  • The Beard
15 Jan 2016 20:23 #12 by The Beard
lol yes I think your right im going for a couple of civvies
15 Jan 2016 20:27 #13 by Garry Pollard
The Beard wrote:
the only problem ive come across is rather major,I dont think the receiver and controller communicate .There is no instruction to bind and I cant see anything that looks like it should be bound and there is no instruction or mention of the receiver.Plug the battery in and all you get is steady alarm and the receiver has a flashing red light .Ive fitted Futaba receiver and it is working perfectly on my futaba controller.One of the retracts was stuck but with a little pull it came down and both work fine now
Just a thought on RX/TX Stephen Usually the RX binds to the TX automatically, BUT you have to turn the TX in first, otherwise it wont bind . Give it a try
  • The Beard
15 Jan 2016 20:36 #14 by The Beard
Yes Garry did that tried half a dozen times and same result .fitted Futaba and all well
Thanks: Garry Pollard
  • The Beard
15 Jan 2016 20:38 #15 by The Beard
ive assumed these plug and play thingies should be bound already but no joy with this set up.Im sending both back to nitrotek see what happens
Time to create page: 0.792 seconds
