- Thank you received: 1476
Tony Nijhuis Concorde build
- Ralpharr2001
First up is the wings. No major dramas here. Just packing under the leading edge, slot the ribs into place, check alignment and drip some thin CA into each joint. Repeat for the other side.
- Ralpharr2001
Cracked on again today with the build after I changed brake pads on my car. Wasn't happy with the old pads, bad brake fade under heavy braking so went up a grade to some road/track day pads. Seems to have made a positive difference. Anyway, I put the top sheeting on each wing, added the fuselage formers and put some longerons in. Built the nose section. Took quite a bit of time to make sure everything was straight and the wings were sitting on the build tabs so no twists. Started installing the wiring and servo extensions.
Road n track pads won't help.with fade, just give more "feel" ( I like EBC green stuff pads) sounds like your due a fluid change tbh, brake fluid is hydroscopic.
- Ralpharr2001
- crash happy
- Thank you received: 1203
- Ralpharr2001
Anyway, on with the build. Crash, it will weight around 5lbs, Tony Nijhuis recons 4.85lbs (2.2kg). The FMS fans on 4S give about 700g thrust, so just over 1:1 power to thrust.
Today was sheeting the underside of the wings and fuselage. I preformed the fuselage sheet over a plans tube I had that was a close diameter to the fuselage. Just apply water to one side, clamp around the tube and bake until dry! On the plans Tony shows the fuse sheeting goes from the front of the wing to the rear. I am worried that the nose section join at this point is a potential stress point as none of the longerons run through into the nose. The nose worries me as that carries the front nose leg. So I decided to run the sheeting just (about 50mm) forward and aft of the front and rear formers to spread the load into the sheeting.
Cut and trimmed the vacuum forms for the nose.
Added a plastic strip to join the two halves together. This gives a supported joint and is easy to fill.
- Ralpharr2001
Played around with the nose vac forms. Got the cockpit one on by installing a dummy former to support it. Installed the snake to lower and lift the nose. The main nose cone needed some fettling. It wasn't the right profile to go over the cockpit section, need adjusting to make it more oval in cross section. So applied a little heat to manipulate it and wham it distorted!!
Made the control surfaces and epoxied them onto the torque rod that goes over the engine nacelle. Used a piece of ally angle to to get the alignment.
I'm still waiting for my EDF units to arrive. So that will limit me installing the nacelles. Anyway I can still build and cover them then glue them on later. Getting close to the covering stage. I'm going to cover it in white solarfilm or oracover, whatever I have in the drawer.
Quite correct Ralph
Vac forming leaves considerable stresses in the plastic. Only with a moulding process where all the material remains fully plastic until the final shape is obtained will the residual stresses be eliminated or at least very substantially reduced.
Wow a drooping nose!
Of course to be true scale the 'drooping' is a two stage process. The canopy shield first, then the nose.
- Ralpharr2001
Needed some servo covers and was about to design some on Fusion but thought I would check on Thingiverse. I found these, www.thingiverse.com/thing:2901556 and printed a pair. Really nice design and the designer included the drawings in his files so you can see the size of the covers. He does two sizes. That saved a lot of time.
Decided to make a start to the engine nacelles. Quite simple construction. Tony used his normal method for rounded corners, he uses large triangle section into each corner then sand away most of it. I don't have the EDF units yet, they are on a slow boat from China for the third time. First time they never arrived after 6 weeks so got a refund. Then they shipped again and they were returned to the supplier from Chinese customs for a security issue. So third time they have been shipped and are hopefully on their way. So without the EDF's I have built the nacelles off the plane straight off the plan. Using the Dremel (what would we do without one of these??) I managed to get a nice internal radius to the triangle section. Overall quite pleased.
- supertigrefan
- Thank you received: 513
- Ralpharr2001
Actually none of the above!
www.axminstertools.com/mirka-dust-free-s...branet-sheets-101148
Expensive to start with but like any professional tool worth its weight. I bought this kit about 5 years ago and only used about a dozen abrasive pads and I build a lot. Either they dont wear out or i'm tighter than the proverbial ducks bum under water, or both!!
