Jet Wing
04 Nov 2024 17:57 #1 by Klipkopwildlife
Jet Wing was created by Klipkopwildlife
I've got a number of 3D print builds on the go (just call me grasshopper) but I've never built or flown an EDF plane so I thought I'd document this one.
It's the Jetwing by Plane Print
These are the fuselage parts
And this is how it all goes together
There are 2 different fuselage configurations, One with no rudder and one with vectored thrust. This one will be no rudder to keep things simple.
There are also 2 wing spans, 1270mm and 2060mm, this fuselage will have the 2060 wing and will weigh close to 2kgs
Thanks: Flytilbroke, jon.in.swansea
04 Nov 2024 21:02 #2 by Quorneng
Replied by Quorneng on topic Jet Wing
Wow!
First EDF, a flying wing and a 4s 70mm EDF!
I am sure it will fly but at 2kg you will find it fast with all the stress that gives until you get the hang of it.
The problem is at its speed 2 mistake high makes it really high and thus all to easy to loose orientation.
Keeping speed under control is the main reason I build "silly light" EDFs.
Eye sight and reactions are not what they used to be!
05 Nov 2024 07:40 #3 by jon.in.swansea
Replied by jon.in.swansea on topic Jet Wing
I 2nd the WOW - a 2m span, take care going through doorways!  Not to mention the stresses of taking off and landing on your lumpy field or catching a tip.
Must look up and see some video of this beastie in action.....
05 Nov 2024 08:13 #4 by Klipkopwildlife
Replied by Klipkopwildlife on topic Jet Wing
Silly light is not an option for me Simon, I've been waiting for weeks now for flyable weather, 41C the last 2 days, up from 38C average. The gusts start as early as 0700! My weather station shows gusts of up to 35kph in the middle of the day as the thermals come through.
The 2M wing has a loading of 28gm/dm as opposed to 48gm/dm (whatever those figures mean) also the 2M wing is a 4 flap wing which will allow things like flaperons and Crow braking. The small wing is going to be a real rocket ship, I'm the same as Simon, eyes and reactions are failing.
05 Nov 2024 09:08 #5 by Klipkopwildlife
I see the FunCub is 30gm/dm, probably more since all the repairs, so, as long as I remember that I've got a throttle the big wing should be flyable with my skill set.
Thanks: Flytilbroke, Quorneng, jon.in.swansea
16 Nov 2024 13:58 #6 by Klipkopwildlife
Well I got a bit of a break, (laying a floor in our new bedroom, if you really want to know), it takes longer to fettle the parts than it does to glue the parts together
17 Nov 2024 07:51 #7 by Klipkopwildlife
Centre section halves
And the tail pipe on, lower half
Cockpit section
And the nose
Fin and upper tail pipe, not yet glued
EDF in, I had to lengthen the motor wires
And motor cover complete
Thanks: Eric, Flytilbroke, Quorneng, jon.in.swansea
17 Nov 2024 11:32 #8 by Quorneng
Those are superb quality prints.
I wish mine were as good!
17 Nov 2024 16:46 #9 by Klipkopwildlife
No credit to me, fine tuning of Cura 5.8 and my Prusa mk4 which really is the bees knees.
Thanks: Eric, jon.in.swansea
22 Dec 2024 13:41 #10 by Klipkopwildlife
Moving on, I've abandoned the fuselage at the moment to concentrate on the wing. I have a number of sections that didn't complete and have found a way to repair them, courtesy of Plane Print.
Time to create page: 0.240 seconds
