Weston UK Cap 232 Build Blog
02 Sep 2013 20:59 #31 by Ex-Member
Replied by Ex-Member on topic Weston UK Cap 232 Build Blog
or just buy new and be done with it. :P
02 Sep 2013 21:02 #32 by Garry Pollard
Replied by Garry Pollard on topic Weston UK Cap 232 Build Blog
Tony B wrote: or just buy new and be done with it. :P
That would be my preference
02 Sep 2013 21:06 #33 by Klipkopwildlife
Replied by Klipkopwildlife on topic Weston UK Cap 232 Build Blog
Tom T wrote: Thank you Beard, I will certainly give it my best shot. Once I have located and bought some covering I'll do some experimenting before covering. Should be a lot of fun if nothing else!
I have been offered these, they are £15 for the lot of them, views please..
Sorry, I meant Tom, perhaps just 5 minutes then!
02 Sep 2013 23:22 #34 by The Beard
Replied by The Beard on topic Weston UK Cap 232 Build Blog
Never had a problem with Futaba servos whatever vintage and new ones often sound rougher.
03 Sep 2013 11:16 - 03 Sep 2013 11:16 #35 by old fart
Replied by old fart on topic Weston UK Cap 232 Build Blog
The Beard wrote: Never had a problem with Futaba servos whatever vintage and new ones often sound rougher.
Maybe because they're new, i,e, new and tighter geard and bearings etc. ;)
Last edit: 03 Sep 2013 11:16 by old fart.
03 Sep 2013 15:35 #36 by Ex-Member
Started the dreaded covering today.
rudder, tailplane, elevators and nose covered.
still don't like iron on covering, but i have to master it. so i will plod on.
  • Tom T
  • Tom T's Avatar Topic Author
03 Sep 2013 17:47 #37 by Tom T
Replied by Tom T on topic Weston UK Cap 232 Build Blog
Looking good Tony! Looks well on it's way to it's maiden flight :whistle: Do you know what servos and things you are putting in? :) Keep up the good luck, haha :woohoo:
(Sorry I haven't commented earlier, been busy :unsure: )
03 Sep 2013 19:53 #38 by Ex-Member
Fuselage is covered now.
not the greatest of jobs, but it looks ok from a distance.
waiting for servos and motor now, so i will be stalled till they turn up.
just using normal large size tom from giant shark.
04 Sep 2013 06:24 #39 by bogbeagle
Replied by bogbeagle on topic Weston UK Cap 232 Build Blog
Never buy second-hand radio gear ... imo.
  • Flytilbroke's Avatar
04 Sep 2013 11:58 #40 by Flytilbroke
Replied by Flytilbroke on topic Weston UK Cap 232 Build Blog
Post 33. They look as if they have had a hard life, I would not use them in other than a model I did not really care about.
04 Sep 2013 21:30 #41 by Ex-Member
not looked at it today, had house maintenance to do.
but i did find that the covering had bubbled where it was sat on the bench in the sun, re shrunk it.
hope this is not going to keep happening.
servo's turned up today, so if i am allowed in the shed tomorrow, i might try to finish the fitting out.
04 Sep 2013 22:40 #42 by Klipkopwildlife
Tony B wrote: so if i am allowed in the shed tomorrow, i might try to finish the fitting out.
whoops, I know that situation so well!
05 Sep 2013 16:36 #43 by Ex-Member
Well after cutting some logs for the winter i got into the shed.
rudder and elevators fitted, hinges all pinned as well.
the twin elevator servo's are in and all connected up.
got a problem with the pull pull set up for the rudder, the wires are not long enough to enable me to get the servo on the cog point, so i will need sort out some fishing trace wire at the weekend to re do it.
Tail wheel is fitted.
wing bandage is now setting and then i can sort the ailerons and cover the main wing.
spats are fitted and drying.
been a long day with not a lot to show for it, this is the reason i hate fitting out, takes ages to do very little.
hence i have loads of models at this point and then forgotten about. :(
06 Sep 2013 14:55 #44 by Ex-Member
what to say about today.
not a lot i expect.
u/c is back on.
pull pull on the rudder is sorted and working.
motor is mounted
cowl is on.
canopy is trimmed a bit more.
slopped a bit of paint about.
need a second coat on the cowl.
the wing bandage has set fine, so i can do the aileron servo's later and then cover the wing.
got to sort out a battery tray and fit the esc and rx, job done.
06 Sep 2013 15:20 #45 by Garry Pollard
Well done Tony, you dont hang about, do you ??? LOL
Time to create page: 0.194 seconds
