- Thank you received: 215
Panic! - now why did I do that
- RobC
27 Jun 2014 11:44 - 27 Jun 2014 11:47 #1
by RobC
Panic! - now why did I do that was created by RobC
you know how it is, your idly browsing through ebay and an item catches your eye so you throw a bid in. That's what I did on a
Panic
, then forgot all about it. It seems I won, now I need to make a trip up to Webbs to pick up an antique Panic.
I just hope some of the advertising will peel off ok.
OS61FX maybe?
OS61FX maybe?
Last edit: 27 Jun 2014 11:47 by RobC.
27 Jun 2014 12:58 #2
Replied by Eric on topic Panic! - now why did I do that
I've got an unstarted wooden mk 1 somewhere, too! A 61 would be 'adequate' !
but for real fun, put an 80 or so in it!
(and take two pairs of bike clips!)
I've been trying to figure a way of electrifying it, the problem is getting the c of g far enough forward without stuffing half a church roof in, because it has a very short nose.
27 Jun 2014 13:06 - 27 Jun 2014 13:06 #3
by old fart
Can we ask what the bid was?
Replied by old fart on topic Panic! - now why did I do that
RobC wrote: you know how it is, your idly browsing through ebay and an item catches your eye so you throw a bid in.
Last edit: 27 Jun 2014 13:06 by old fart.
27 Jun 2014 13:08 #4
Money???
- RobC
27 Jun 2014 21:43 - 27 Jun 2014 21:45 #5
by RobC
Replied by RobC on topic Panic! - now why did I do that
£50 'best offer'. Most of the ones I've seen have had servos and motor fitted, and seem to go for 120-150, so I thought 50 a more than fair price - now I wonder if £40 would have done it.
I picked it up today, what a nightmare on the M6! What should be a 90 minute trip took 3 1/2 hours.
Anyway, the model - very good condition just needing a run over with the iron to get rid of one or two wrinkles. It's the foam wing version, set up for 4 aileron servos and came with neccessary extension leads, control rods, closed loop rudder etc. 7 servos, a receiver, battery and engine will see it ready to go. I picked up 6 ES300 standard size servos for £3-75 each as recommended by Robin in Steve Webbs and I've plenty of odd ones to make up numbers. Anyone tried running JR 517 or 591 on 6.6v?
A new ASP53 or old OS61FX will go on the front depending on which one fits the bearers. I've got shorty pipes to fit either one
so power should be sufficient.
Thinking about it, the tank looks to be either 8 or 10oz, so probably the 53 would be a better choice.
Last edit: 27 Jun 2014 21:45 by RobC.
Thanks: old fart
Time to create page: 0.158 seconds
