Harmon Rocket
  • The Beard
17 May 2017 21:54 #46 by The Beard
Replied by The Beard on topic Harmon Rocket
battery in position andsecured as id the receiver.a box arrived during the day,didnt have a clue what it might be .Its my 2nd controller back fromn manufacturers repaired,they found a fault and repaired foc.they checked the receivers and there ok .good news except the lipo battery is no longer in it ,oh dear
Thanks: boz, Firewood
17 May 2017 22:31 - 17 May 2017 22:33 #47 by one tenor
Replied by one tenor on topic Harmon Rocket
Is this the thing about batteries/Lipos in appliances in mail maybe ? I can't recall the exact ruling.
Last edit: 17 May 2017 22:33 by one tenor. Reason: additional script
  • The Beard
18 May 2017 19:17 #48 by The Beard
im unsure as ive received batteries lipos from e bay but you mean actually fitted in a device,no note enclosed so not sure as yet
  • The Beard
18 May 2017 19:19 #49 by The Beard
some issues at the field one being engine wouldnt start so morework needed .came home to rain so couldnt explore further as yet
Thanks: one tenor, boz, Firewood
  • The Beard
20 May 2017 16:30 #50 by The Beard
bit strange at the field it was messing about but at home its perfect
20 May 2017 17:53 #51 by one tenor
Yes I've seen something to that effect . Not sure what difference it makes in or out
  • The Beard
22 May 2017 11:40 #52 by The Beard
although the battery said 6v i charged it and seems the problem was low battery
  • The Beard
22 May 2017 11:56 - 22 May 2017 18:16 #53 by The Beard
at the field
Last edit: 22 May 2017 18:16 by .
  • The Beard
22 May 2017 11:59 #54 by The Beard
and
Thanks: Quorneng, boz, Firewood
  • The Beard
24 May 2017 15:32 - 24 May 2017 15:48 #55 by The Beard
spent some time setting the engine up on the Rocket and it started and was tuned immediately,just had to get throttle adjustment right and that was easy.On take off my natural flight pattern is right.so when on take off it flipped over left I was flumaxed.It cart wheeled and took the engine off.When home it was a very easy repair and no damage just the engine wooden framed front of fuselage where engine mount fits ,the box and come clean off .just needs gluing back.I was unable to check controls as wiring was unplugged
Last edit: 24 May 2017 15:48 by .
  • The Beard
24 May 2017 15:44 #56 by The Beard
easy repair
24 May 2017 15:50 - 24 May 2017 15:54 #57 by
Replied by on topic Harmon Rocket
You do do a good job of repairing them Stephen, however, to be fair, you seem to get a hell of a lot of practice :evil: [badass]
Do you do a pref light check of all controls with and without engine running plus of course the mandatory range check ?
Last edit: 24 May 2017 15:54 by .
  • The Beard
24 May 2017 16:02 #58 by The Beard
yes i have a set routine i go through but latter part of last year and this year have been catastrophic.ive lost a lot of confidence.If you had seen me trying to take off with the pulse yesterday youd have thought I was a beginner .It was really bad so bad it became comical.Once I properly went for it I was ok.Im going to reduce the rudder movement i was overcorrecting
25 May 2017 03:25 #59 by one tenor
You think you've got probs. God knows what I'll be like as I haven't flown for over 40 yrs. I can't even recall how to hook up my old radio gear. As for all the new electrics and new Tx 's and Rx's and their attendant additions,well it is way way over my head. I only want plain and simple but will take some relearning. Keep on trucking as they said way back,you'll pick things up again. John
  • The Beard
25 May 2017 11:44 #60 by The Beard
thanks,ive had lapses like this before and come out the other side a better flyer
Time to create page: 0.235 seconds
