Hangar 9 Carbon Cub
Their power output against the ones in the days gone by has also increased, and bearing in mind that we were restricted to OS and Merco 61 with glow engines , nothing bigger was allowed.
These days it would appear there is no restrictions , and it is only depth of pocket which seems to matter. Having said that the prices of the dedicated petrol engines for models I feel is very reasonable for what you get
There are as many petrol ones at Langar as glow.
I've never used petrol myself, (except in road cars!), but once set up properly, they are very good, reliable, and frugal!
You do need petrol-proof fuel tanks, lines etc, though, you cannot use silicon or plastic, as the petrol eats it!
- Septic
- Thank you received: 690
Sorry cannot help with petrol, never used one in a model....
tap - tap.......rivet
- Thank you received: 10722
So make sure everything is well glued, and bolts to hatches put some fuel tube on them to stop them coming loose that's what I will do when I vac form a new cockpit
Apart from that they are good you will not want to go back to glow
Another thing, be careful, these big buggers bite!
I use a six volt 2000 nihm on mine, on my Revolver I run two 2s 2200 lipos through a sensor switch, I plug the ignition into the spare channel on the receiver, works fine
I start my 50cc by hand no glove, bit me once, eye watering experience.
