Peanut Scale Westland Woodpigeon
16 Nov 2015 22:46 #76 by one tenor
Replied by one tenor on topic Peanut Scale Westland Woodpigeon
Thanks Andy , I thought he would be . I met Butch as a young, much younger, man .This was in '58 at Abingdon and his reputation was growing then. Doug McHard was also there with a similar rep. Some of the others were at the meet too but never met them . I never got to many dos outside Lancs and Cheshire. Bikes ( and motor bikes ) and models have a limiting factor on travelling far. .Woodford and Woodvale were about as far as I could get usually. I found them both to be very nice chaps and full of hints and tips
16 Nov 2015 23:58 #77 by one tenor
Andy in the "Olde " days a type of varnish called banana oil was used on lightweight frames. As far as I know it had nowt to do with bananas but gave a nice finish. What about trying a diluted varnish such as Humbrol clear .They used to do a Marine varnish which was fuel proof although it wasn't claimed to be so which sprayed well. It may be worth a try .
17 Nov 2015 07:41 #78 by Ex-Member
Replied by Ex-Member on topic Peanut Scale Westland Woodpigeon
I've had a re-think on the fuselage and looking back at older photos (see post 64) the starved-horse appeared after water shrinking and before doping. Also, non of the other parts have exhibited any shrinkage after doping.
I've learned recently that the after effects of anaesthesia last up to 6 months. My heart op was on 10th Aug, so maybe that was the reason I didn't notice in the first place. It's not an excuse, but it's nice to find a reason for these things!
Looking at your comment John, banana oil is simply non-shrinking dope with a plasticiser added. We used to make our own by adding a few drops of caster oil to non-shrinking dope. I still have some original banana oil in the dope store but it doesn't give me the finish I want on the scale model I'm building. It's good for sports models, though.
17 Nov 2015 10:00 #79 by Klipkopwildlife
Replied by Klipkopwildlife on topic Peanut Scale Westland Woodpigeon
I love your work Andy and would love to be able to do FF here but it's just not feasible. Please explain stooge and blast tube, torque meter is of course self explanatory.
17 Nov 2015 10:28 #80 by Ex-Member
Klipkopwildlife wrote: I love your work Andy and would love to be able to do FF here but it's just not feasible. Please explain stooge and blast tube, torque meter is of course self explanatory.
Apols Klippy, I've been assuming too much from you 'radio types' ;) ;)
Blast tube: a tube that is inserted over the rubber motor inside the fus of the model to protect the model from the rubber bursting while it is being wound.
Stooge: anything that holds the model while the rubber motor is being wound. It can be in the form of a mate, or a mechanical structure.
I'll add some pics when I next get into the model room.
17 Nov 2015 11:39 #81 by one tenor
It was just a thought Yep I know the castor oil trick. It is/was used to make microfilm too. If you are looking for a high gloss I suggest the varnish be given a try .
17 Nov 2015 12:30 #82 by Ex-Member
one tenor wrote: It was just a thought Yep I know the castor oil trick. It is/was used to make microfilm too. If you are looking for a high gloss I suggest the varnish be given a try .
Humbrol varnish is not suitable for lightweight scale models John (one tenor), it is far too heavy.
A hi-glass finish is not appropriate for competition models of this size. Scale effect requires a slightly duller and paler finish.
18 Nov 2015 03:35 #83 by one tenor
Was just a thought If not for the weight penalty Matting agent could have been added for a semi matt effect. Never mind Eh!
30 Nov 2015 20:18 #84 by Ex-Member
Slow progress! I've joined the rudder to the fin using 0.012" music wire, or to be more precise, a used 'A' string off my mandolin.
The flaperons have been joined with small diamond shapes of thin ali cut from a ring-pull lid from a sweetcorn tin.
08 Mar 2016 18:27 #85 by Ex-Member
It's high-time I progressed this one, so the flying surfaces have been joined to the control surfaces:
08 Mar 2016 18:42 #86 by Ex-Member
ooooooooooooooooooh that looks nicely done.
smashing. :)
10 Mar 2016 00:57 #87 by one tenor
Lovely work sir .Rminds me of building microfilm jobs in days of yore . Well done :woohoo: :lol:
10 Mar 2016 05:46 #88 by Ex-Member
Model has now been lightly sprayed with non-shrinking dope, thinned to about 30%, and pinned down when touch dry:
There's one or two wrinkles appeared that I'll have to sort before final finishing, but otherwise, all looks OK so far.
11 Mar 2016 02:18 - 11 Mar 2016 02:20 #89 by one tenor
Lovely sir
Last edit: 11 Mar 2016 02:20 by one tenor. Reason: correction
11 Mar 2016 07:31 #90 by Ex-Member
I had intended to get this one ready to fly for the Peterborough Club's indoor meeting at Bushfield Leisure Centre this weekend, but..... I'd forgotten to put a coaming on the bus.
So, discs were cut (with a few spares) from light balsa (6lb/cu ft) using a compass-cutter:
edges were radiused using fine sandpaper:
and the inner circle cut out:
The resulting 'ring' was then cemented to the cockpit - front completed in the photo, rear one to be done:
Next job will be to shape the inner part of the ring, then sealing the result with dope.
Time to create page: 0.362 seconds
