Keil Kraft Gemini
  • Andrew Darby
  • Inactivated User
  • Inactivated User
29 May 2017 19:26 #1 by Andrew Darby
Keil Kraft Gemini was created by Andrew Darby
Hi all,
I am after a kit either to buy or borrow for the above to trace the parts. It is a sweet little rubber powered free flight model with sheet fuselage and a built up wing, ideal to build with my lad...
Ta
Andrew
29 May 2017 22:24 #2 by one tenor
Replied by one tenor on topic Keil Kraft Gemini
Aerofred or similar free sites should have it . I'll have a look too.
30 May 2017 01:02 - 30 May 2017 01:09 #3 by one tenor
Aerofred or similar free sites should have it . I'll have a look too. found this so far
outerzone.co.uk/planfile_supplement/7529...5_oz7529_article.pdf and this version ..The Invader glider might suit too. Should convert to power of one sort or other outerzone.co.uk/plan_details.asp?ID=7529 one or the other sort. This one is free Same plan
Last edit: 30 May 2017 01:09 by one tenor.
  • Andrew Darby
  • Inactivated User
  • Inactivated User
30 May 2017 19:15 #4 by Andrew Darby
Replied by Andrew Darby on topic Keil Kraft Gemini
Hi, thanks but it isn't the right model, this is a kit made by Keil Kraft, of a rubber powered free flight model...
  • Andrew Darby
  • Inactivated User
  • Inactivated User
17 Jun 2017 19:25 - 17 Jun 2017 19:31 #5 by Andrew Darby
I found not just one but two in a shop in Athens Greece, for 13 Euro each. I bought both. I will trace the parts for anyone else who would like to build it.
Andrew
Last edit: 17 Jun 2017 19:31 by .
Thanks: Quorneng, boz, Nigel
17 Jun 2017 23:48 #6 by one tenor
one tenor wrote: Not Gemini but looks familiar though
www.hippocketaeronautics.com/hpa_plans/d...ls.php?image_id=7878
Dammit Pic didn't come out. It's a bipe looking like a Gemini
18 Jun 2017 11:14 - 18 Jun 2017 11:23 #7 by one tenor
Found this from Derrick Scot mail.google.com/mail/u/0/#inbox/15cb7e9536edea30
In case this doesn't read He has the plan with coloured diagrams .£ 4.50 +£ 1.75 P.P, so if anyone wants to get some grab 'em
This email address is being protected from spambots. You need JavaScript enabled to view it. is his E mail
Last edit: 18 Jun 2017 11:23 by one tenor.
  • Andrew Darby
  • Inactivated User
  • Inactivated User
18 Jun 2017 14:41 #8 by Andrew Darby
Yes, or save the £6.25, and go get the plan and traced parts over on hip pockets FOR FREE, (in a few weeks once I have trace them) Then use the money to buy the balsa and a 7" prop and still have change for an ice cream whilst you are watching it circling above your head on a sunny day B)
Andrew
Thanks: , boz, Squirrelnet
18 Jun 2017 22:08 #9 by Eric
Replied by Eric on topic Keil Kraft Gemini
OT, if you click on your 'thumbnail pic, it works ok. I suspect you forgot to click the add link button, when you typed out the message!
18 Jun 2017 22:24 #10 by one tenor
Thanks Eric Clicked it but nothing showed up .It was bipe looking like a two winged Gemini
18 Jun 2017 22:29 - 18 Jun 2017 22:30 #11 by Eric
Sorry - finger trouble! It was Andrew Darby, not OT. :oops:
and you need to click 'add file', select the file, and then click 'insert'.
Last edit: 18 Jun 2017 22:30 by Eric. Reason: added a comment
18 Jun 2017 23:10 - 18 Jun 2017 23:38 #12 by one tenor
Had trouble logging onto Hip Pocket that's why I missed it Thanks for that I would have to bite the bullet and buy the plan as my printer is SNAFU and would cost a lot more to repair so I'm behind the 8 ball as they say.Either that or wait till I'm on my feet and fix it myself. It's an ink problem .Left in the machine to dry.Got two others with same problem. Son bought new ones when the others dried out.He wouldn't let me sort the others for some reason. Now says I can when not able to do them / He's 40 so can't blame puberty for his attitude can I ? LOL
Last edit: 18 Jun 2017 23:38 by one tenor. Reason: additional script
19 Jun 2017 00:09 #13 by Eric
Early Onset Male Menopause? :evil:
19 Jun 2017 03:45 - 19 Jun 2017 04:00 #14 by one tenor
Eric wrote: Early Onset Male Menopause? :evil:
It's rather late for that mate he's always heard a different drum Re not able to log in I can't see why .However the fault is in their site .Even changing username and password won't let me in.I am beginning to think someone there doesn't like me LOL [badass] Cheers Eric
Last edit: 19 Jun 2017 04:00 by one tenor. Reason: Correction and addition
  • Andrew Darby
  • Inactivated User
  • Inactivated User
22 Jul 2017 15:11 - 22 Jul 2017 15:11 #15 by Andrew Darby
Finally traced the parts and built this rough prototype.
There was lots of errors on the die cut sheets including the two main formers with the grain in the wrong direction! I'm going to see how this flies soon...
Andrew
Last edit: 22 Jul 2017 15:11 by Andrew Darby.
Thanks: Quorneng, , boz, Firewood, Squirrelnet
Time to create page: 0.322 seconds
