- Thank you received: 573
VMC 150% KK Hawker Fury for Rubber FF
So, here's the kit:
And here's how far I got last night. I'm using jigging blocks twice the size of the fuselage longerons so that I can build one side over the other using the same jig. The ruler is used to ensure the jigging blocks are in line.
followed by the lower wing and second fuselage side over the first:
Spars added to the upper wings and the tailplane has been laid down (I've made provision for separate elevators for trimming);
and I've cut some wood to allow a built-up rather than solid fin in an attempt to save weight behind the C of G:
- Mike Rolls
one tenor wrote: Very nice Andy I've been trying to find the kit on VMC site. How did you find yours ?
They've removed it from the site, John, as the parts don't fit too well. Apparently, it was put up in error when I ordered mine, but they honoured the order anyway.
VMC are working on all their inherited kits to bring them up to their high standard.
If you're desperate for one, download the Veron plan from Outerzone and multiply it, and the print wood, by a factor of 1.5
- Squirrelnet
- Thank you received: 2067
The Outerzone plans are very easy to scale as they are usually 1 PDF with both plan and print wood to the scale . So 150% increase effects both. Worth checking the print wood over the plan though to be accurate, I've had couple that needed small changes to the print wood size to match properly
- Andrew Darby
- Inactivated User
- Thank you received: 234
Tailplane off the board:
and shaped. I've since removed and replaced the part that's dried skew-whiff:
The wings are also off the board:
The fuselage sides have been sanded, matched and joined:
...and formers and wing locating tubes added:
I've also completed the fin/rudder, but failed to take a photo. I'll rectify that next time.
I've made a classic error on the tailplane and assumed that the elevators were of the simple type. The full size has a rather large balance horn, so I'll need to add some wood to the tailplane to allow the correct shape to be formed.
Have you dyed the balsa? or is it just a photo thing.
- Squirrelnet
Good thing you noticed now and not after you had covered and painted it
Squirrelnet wrote: Good thing you noticed now and not after you had covered and painted it
Yep, I'll eat humble pie on that one Chris.
It's a photo thing Q, the picture was taken on an iPhone under electric light.
- Squirrelnet
I like your neat solution to the elevator line
