- Thank you received: 236
Pendulum??
- ColibriGuitars
- Senior Member
Cheers!
- Squirrelnet
- Thank you received: 2067
An old idea that didn't work particularly well in its day. I think Bill Dennis wrote a bit about them recently in Aeromodeller I'll see if I can dig it out but it was along similar lines to my opening statement. There was a thread on here that mentioned them too ( edit - just done a search and it is in the DH60 build thread)
With a stable design like the Tiger Moth you really don't need it.
With an elevator pendulum it makes launching very tricky as the inertia of the launch effects the pendulum and I remember reading somewhere an account of taking a pendulum to be used for the rudder up in a fullsize aircraft and in a balanced turn the pendulum does not move anyway
In the 1950's there were lots of weird and wonderful ideas for pendulums including ailerons and even throttle, often the models illustrated carried the caption 'as yet untested' which I think says it all.
- Mike Rolls
- Thank you received: 573
- Neddy
- Junior Member
- Thank you received: 45
Are you looking at the Keith Laumar design - it seems he suggests pendulum is optional. I would be inclined to replace the sheet fin and tailplane with built up versions for weight saving but for my part would be favouring the Henry J Nichols design because I know that one flies well and is only slightly larger - 33ins span
- Neddy
- Junior Member
- Mike Rolls
Here's a quick reminder on posting pictures, after loading the picture, you need to insert it where you want it in the text. So, after loading the picture, place the curser where you want to picture to appear, then hit the 'insert' button which will appear in the 'Attachments' line after you have 'added' the picture. I've inserted the pictures in your above post at the end of your text.
- Neddy
- Junior Member
Neddy wrote: Thank all - and Andy - bear with me I am slow but so was the tortoise!
No probs Neddy - if you read way back in the threads, you'll see that most of us have failed to insert our pictures on our first few posts.
- Robin Colbourne
- Junior Member
- Thank you received: 62
- Thank you received: 14305
- A Free Flighter From Oz
- Senior Member
- Thank you received: 144
* D *
