1942 mini Wakefield "The Jay"
First job was to complete the prop assembly, the spinner is constructed from 2 discs of hard 1/32 balsa and the cone shape built up from rings of soft sheet, 3/32 was the softest I had to hand.
after a good sanding it's time cover it in tissue and dope ....watch this space.
- Thank you received: 10722
hopefully in a couple of days I should have something structured to show.
tail feathers next.....maybe!
- Ausmodeller
- Junior Member
- Thank you received: 30
u/c plugs into rolled paper tubes glued into the fus.
tail needs shaping and sanding then it's the wing....
Looking good young man
weight so far is about 1 1/2 ounces...
Looks so fradgile
- Thank you received: 14305
I thought to keep the thirtys sort of flavour I'd finish it in silver, bad mistake, I've discovered silver tissue is possibly the most un user friendly material known to man, it may just me but the bloody stuff just will not behave, after stripping and recovering it twice I'm going to live with the wrinkles!!
