Flying models without a radio
Model Paint
- silbchris
- New Member
14 Feb 2020 11:49 #1
by silbchris
Model Paint was created by silbchris
Hey guys,
How's it going? I'm fairly new to this forum and just properly getting into model building. I've recently started getting headaches and I think it's from the paint. Has anyone else experienced this? I was looking at respiratory protection like this . Anyone got any recommendations on this? Looking for something that'll work but will be fairly inexpensive.
Cheers,
Chris
Cheers,
Chris
14 Feb 2020 13:01 #2
Replied by Quorneng on topic Model Paint
silbchris
What type of paint is are you using that you think is causing the headaches?
If the headaches are indeed from the paint then the respirator has to be for vapour filtration rather than the more common particulate.
The normal solution to vapour irritation is lots of ventilation or change to a non irritant (water based?) paint.
14 Feb 2020 17:52 #3
Replied by Eric on topic Model Paint
Have you also been ujsing cyano/superglue/instant glue?
Headaches and nausea are common side-effects from breathing the fumes.
Ventilation is the key.
As Q put, a dust-mask is useless for this problem.
- crash happy
- Thank you received: 1203
14 Feb 2020 22:08 #4
by crash happy
Replied by crash happy on topic Model Paint
If in doubt, use a charcoal filter mask. I doubt if they cost more than ten or twelve quid over there. Get a couple of spare filters while you're at it.
Better to be safe than sorry!
Time to create page: 0.171 seconds
