Full size engine silencing
The model engine is, and when a tuned pipe is fitted they can be really quiet, but very little loss, or maybe a gain in power.
I asked the question on livechat to our resident full size pilot, Andy, and he didnt know.
So the question is, why arnt they silenced more effectively . Anyone know ???
- Inactivated User
In general no, although most radials use an exhaust collector ring which reduces the noise considerably..Turbo charged are much quieter (P38 or P47) because of the muffling effect of the exhaust turbine.
Of course the yank 'quiet' planes used in Vietnam were fully silenced.
They were supposed to be inaudible at 1200ft even at night.
I suppose some like the Bristol Fighter had very long pipes which would add a degree of silencing but was really done to duct the exhaust away from the pilot/observer.
I suspect the real reason (apart from cost) is the noise of the prop (Harvard on take off?) is quite significant and you can't do much about that.
That's my two penny'orth.
- CeeJayP
- Hi Peeps
- Thank you received: 833
assuming the engine was a 4 stroke, then the main reason i would think is power, a 4 stroke engine produces its best power when there is little or no restriction on its exhaust, so a short stub or open pipe to direct the flames away is all thats needed, indeed i read somewhere that angling the exhaust stubs backwards helped Spitfires and Hurricanes gain a few MPH, one other reason i suppose is weight as a full exhaust system would not only cost performance but add a lot of weight. whereas a two stroke engine works best with a balanced pressure wave in the exhaust hence the use of "tuned" pipes these can be adjusted to give the ideal length of pipe to give the correct back pressure, this i believe has an effect on the incoming charge into the cylinder and stops a lot of it escaping, if you watch an old glow or diesel engine running in a free flighter you will see that from the exhaust ports comes an awful lot of unburnt fuel, if you want the full story of tuned pipes have a google of Walter Kaaden and particularly Ernst Degner, and how the Japanese motorcycle industry owe him everything!!!
cjp
- CeeJayP
- Hi Peeps
cjp
A two stoke can only 'let' the exhaust out and over a much shorter period so has poorer combustion efficiency but it does do it twice as often as a 4 stoke!
I believe it was Stanley Hooker then working for RR on the Merlin who commented a 4 stroke "has one stroke to produce the power and three strokes to wear it out".
Tuned exhausts work on both types but the improved scavenging it provides obviously has more benefit to a 2 stroke.
- Inactivated User
alan cantwell wrote: Now show me such interesting facts about an electric motor, all you do with those is hit a switch, but then, isnt that the brilliance of the electric motor?
Of course !!! Its for lazy folks, why do you think I use it
I thought Pontiac was American?
Alan wrote - snipped - Now show me such interesting facts about an electric motor,
I had two flights the other day, while another bod was trying to get his four-stroker to run!
Oh yes there are!
Remember the Ward Leonard DC motor control system. Fully reversible with motor braking in both directions but not quite as light as an ESC!
