- Thank you received: 155
- Forum
- Forum Categories
- Full Size Aviation & Model Aeroplane Video's.
- Pair of comedy shorts on the water. Wet Beaver!
- Cpl Jones
- Premium Member
- R.C. aeroplane collector & flyer. FPV lover..
03 Mar 2014 21:20 #1
by Cpl Jones
Jah Baga I... thanks!.
Pair of comedy shorts on the water. Wet Beaver! was created by Cpl Jones
Here's a little 'Mod' I've been trying out. My (VMAR or Hobby King ) size .46 size Kenmore Air DHC-2 Beaver mounted on Hobby King Floats for .20 to .60 size aircraft. The floats have a beautiful finnish. However mounting them is problematic as the hard mounting inserts are pretty short and in a peculiar position on the float. For example, the Kenmore Air Beaver is factory fitted with float mounts that don't correspond with the float mounting points by a country mile. I decided to retro fit hard mounts (2mm ply ) on the exterior of the floats using epoxy then screwing them down dropping epoxy in the drill holes before screwing down. This seems to have produced a strong rigid structure. I added some guy lines as there seem to be some concerns with the strength of the strut frame. 8 cable mounts were provided with the kit .... very generous, however as they all broke whilst being screwed in I too felt a bit screwed.... when the final 2 broke within seconds of being launched... I was screwed! Left without steering I figured I'd give take off a go.... below are the results.
...Ah...just this one for now as the first attempt seems to have disappeared. It was very calm & rudder broken... but as soon as I got home I got out a saw and cut a pair of flaps out of the wing.... maybe just give enough lift..... & 6 cell instead of 4??
Thanks: Eric, blue123, Sarah-Jane Smith
- Cpl Jones
- Premium Member
05 Mar 2014 07:58 - 05 Mar 2014 09:02 #2
by Cpl Jones
Replied by Cpl Jones on topic Pair of comedy shorts on the water. Wet Beaver!
Aah..... lost the first attempt off You Tube for some reason so this is just a re linking to the newly uploaded 1st attempt.
Corporal 'J'
Corporal 'J'
Last edit: 05 Mar 2014 09:02 by .
05 Mar 2014 09:04 - 05 Mar 2014 09:04 #3
by
Replied by on topic Pair of comedy shorts on the water. Wet Beaver!
Should there be a link on your second post Jonesy ??? Or have I misread
Last edit: 05 Mar 2014 09:04 by .
05 Mar 2014 09:23 #4
by The Beard
Replied by The Beard on topic Pair of comedy shorts on the water. Wet Beaver!
water was very calm wasnt it.at least it park itself on the right babk for you
- Cpl Jones
- Premium Member
05 Mar 2014 10:18 #5
by Cpl Jones
Oh me oh my..yuk! yuk! Hee hee! Guffaw..HA-HA!...Oh.. me and my memory... didn't post link.... what a Space Captain...thanks Garry
Yes Beardy... I was lucky second time round... here though is the first shot.....
Jonesy
Jonesy
- Flytilbroke
- Thank you received: 1978
05 Mar 2014 14:07 #6
by Flytilbroke
Replied by Flytilbroke on topic Pair of comedy shorts on the water. Wet Beaver!
A slight ripple and a little oncoming wind and it would likely have managed it. A bit more power,, no probs I think
05 Mar 2014 16:24 #7
Replied by Quorneng on topic Pair of comedy shorts on the water. Wet Beaver!
Although in theory a sea plane can simply 'fly off' the water in marginal conditions it is not unknown to have to 'haul it off'. In other words get it 'unstuck' at the absolute minimum speed even if it then means just skimming the surface until the speed builds up.
There is a lot technology to get the right float V angle, planing angle, step position and step depth, however in most cases just having more power will fix it!
05 Mar 2014 17:38 #8
by
You could always pretend it was a boat Jonesie, in fact it makes a great boat, just take the wings off
![[badass] [badass]](/media/kunena/emoticons/bad_boys_20.gif)
Seriously though, a very good effort mate, you are a braver man than I am . Good effort
05 Mar 2014 19:01 #9
Replied by Eric on topic Pair of comedy shorts on the water. Wet Beaver!
Take a brick on a rope - taxi downwind, lob the brick in, to get the ripples, then take off!
From what I've read, water pilots often hold in full up ele, then apply full power, to get the nose of the floats up, then once they begin to rise, ease off elevator, but keep the 'step' in the water, until you reach flying speed, then a good heave followed by down ele, gets the plane up and skimming just above, while speed increases.
- RobC
- Thank you received: 215
06 Mar 2014 09:57 #10
by RobC
Replied by RobC on topic Pair of comedy shorts on the water. Wet Beaver!
another method (if space permits) is to taxi in a big circle before the take off run so you cross your own wake, that breaks the suction between float and water.
- Forum
- Forum Categories
Time to create page: 0.299 seconds
