- Thank you received: 73
90 inch Lancaster
- Grumpy42
whis1962 wrote: Anyone who scratch builds and take it slowly will find faults and imperfections in the plans and will make amendments will end up with a model that looks and fly perfectly rather than one that ends up on hanging from the ceiling or being salvaged for parts for the next one.
Ah! Obviously a modeler of refined taste and good breeding.
- Grumpy42
Garry Pollard wrote: About time you did some work on the model Grumps, instead of sitting drinking the amber nectar.
Should be maidening it next week sometime ?????????
Dont forget to video it.
Unlike some of the great unwashed on this forum!
- whis1962
- Senior Member
- Grumpy42
Attachment not found
Tailplane and Fins ready for planking and setting up.
Planking on Tailplane.
Two views of tailplane and fins in place.
be finished next week then won't it.
whats in all the plastic tubs, lard or something.
- Grumpy42
Tony B. AKA Blooper wrote: very nice work guv.
- Grumpy42
- Grumpy42
As quite often happens when a project goes on the back burner parts have gone missing, photos have disappeared into the same black hole that traps my socks and the project it's self has suffered some hangar rash. Never the less I did find some of the ribs and stuff to restart the wing - the part that brought me to my knees before.
People who might have followed this thread in the past will remember that my Lancaster is a mere 90 inch wingspan and is being built from an old plan that features foam wings and a brown paper covered ply/foam composite fuselage. Me - being the pain in the arse that I am decided to modify things to use a more conventional and classic build - in other words I decided to scrap all the foam and use balsa/ply through out.
Yeah - well - that meant a complete redesign and I've used the basic outline of the full size plan and changed every thing else. Model is now being constructed from Balsa - Ply. Redesigning the wing meant a complete change of everything including servo placement - adding extra servos - redesigning the engine mountings and nacelles and SCRATCH building a set of retracts!
Oh - I'm also using PROPER model aircraft engines - 4 x 30 Saito 4 strokes. In a couple of days I'll have some photos and a proper update on construction.
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
- Grumpy42
The first job was to get the model down from the wall where it has been hanging for months - I got it down - promptly tripped arse over head and broke it.
The Wall - and the unfinished Lancaster
I picked myself up - swore terrible vengeance on that bloody Wizard who undoubtedly was the culprit who sent the Gremlins - I KNOW I shouldn't have mentioned those 4 lovely Saito 4 strokes - and surveyed the damage. Luckily not to bad and not nearly what I imagined. I knocked both fins off and put my thumb through the balsa skin just in front of the tailplane.
There's an 'ole innit
Luckily no damage to the fins and rudders but a good reason to use dowels when I reattach them.
Then I found some of the wing ribs - including the unfinished centre section ones and drilled them out with a hole saw - saved nearly 4 ounces!! Started to assemble the centre section.
The centre section with the inner nacelles will be permanently bonded to the fuselage -Two outer panels with the outer nacelles will be detachable. This is a very rough idea of how it will go together.
I shall press on.
so i will be watching how you manage it Sir.
- Grumpy42
Re attaching the port fin and rudder
And adding some reinforcement to where I will patch the thumb damage.
And re attaching the starboard fin
This time reinforcing both fin joins with some 1/4 dowel. I'll trim it off after the glue has cured.
The patch to the thumb damage - I wet the balsa before attempting to glue any curved surface.
Attaching the false leading edge.
- Grumpy42
Tony B. AKA Blooper wrote: that is the plan i have for the Manchester build, fix the center section permanently and slide the outer sections on.
thanks Tony. See my comments on your Heinkell HE111 thread - your job will be considerably harder than mine - the Lancaster lends itself to a rather easy solution because the dihedral break is between two nacelles - and of course there are 4 engines as opposed to two.
- Grumpy42
At last count, after my recent encounter with the DR1 I currently have errrr- (1) the Bird of Time; (2) The Fournier RF4; (3) The Texan/Harvard to Wirraway conversion; (4) 2 helicopter rebuilds - (yes I bent one); (5) The Powerhouse crash rebuild; (6) The Phoenix crash rebuild; (7) the Mosquito build; AND
ANY way - bugger confession time - you lot will only laugh anyway - BUT - I wonder how many others on this forum have the same problem - I keep telling myself it's only a hobby and - -- BULLSHIT !!!! - IT'S A FRIGGING OBSESSION ISN'T IT???? -
