BLOOPERS FUNFLY MKI.
So i thought i would resurrect my funfly build.
Made a start on the tailplane and elevator today.
All 6mm square, 6mm sheet and 6mmx9mm that i had in stock, based loosely on the kadet tailplane and elevator.
The main wing is 48" wide and again uses stock lengths of 6mm and 9mm square, with 2.4mm ribs and 1.6mm shear webbing.
just using up the balsa i have and what ever i can get from the scrap box.
Hopefully i can find enough wood for a simple box fuselage with a mid wing design to take a 2200mah 3s battery and reasonable sized motor.
- kamco kid
- has anyone found my marbles?
Will you be putting the finished model through it's paces like those guys at the NATS?
Rich
- SmarTmartY
- Thank you received: 78
I will be drawing up plans for this one and will make templates so i can cut another kit out as and when i need too.( if i crash while trying fancy stunts)
So i could knock up a kit with all the main bits ready cut, so it would be just a case of sticking most of it together and just having to cut the tail yourself.
- Dean M
- Thank you received: 326
This should be RCM&E 2013 mass build
Dean
I nearly choked on my latte.
It's not hard if you sit down and think it out.
Anyone want a kit.
- SmarTmartY
Anyone want a kit.
Me please Tony
An hour a day would see this one built in 2 weeks. ( so miss corrie and eastenders and get the building board out)
Not pushing or anything, need to see if it flies first.
then i have to make templates and buy some more balsa for the kit and then cut out all the parts needed, then make up the kit with the sheet needed to finish it, then bend up u/c, then write up a set of build instructions, then get the plans copied and printed, then get the instructions printed,then find a box, then decide on price,then collapse in a heap hyperventilating.
So next week ok then.
- SmarTmartY
