While I've been sitting on my backside
08 Oct 2012 10:29 - 08 Oct 2012 10:34 #1 by Grumpy42
While I've been sitting on my backside was created by Grumpy42
As noted in another thread I haven't been to well lately and have had to sit around while healing from surgery - so - what do you do when sitting on your backside with nothing to do?? - build a small (ish) IC powered RC model of course. I decided to go through my collection of plans and choose a couple that would be relatively easy to build while sitting down most of the time - hmmmm - then I had a look in the back of the hangar and saw all those half finished or just started projects - Right - first to attack?? - a little 48" W/S Wittman Tailwind (well 48" is "little" to me) that I started and then got side tracked from.
Attachment not found
This is what I had
I added this
And started to put it together
Progress
1/2 way there
Motor choice 4 stroke 30 or 2 stroke 25? Hmmm
Starting to set up the tail feathers. Important to get it all square
Nearly there - Fuselage and Tail Feathers
Last edit: 08 Oct 2012 10:34 by Grumpy42. Reason: Add text
08 Oct 2012 10:38 #2 by Phil Wood
Replied by Phil Wood on topic Re: While I've been sitting on my backside
It's a chunky looking thing isn't it? :lol:
I still love that traditional build style .... it brings back memories of my first rubber powered model that mum & dad bought me when I was a kid. :cheer:
08 Oct 2012 10:44 #3 by Grumpy42
Replied by Grumpy42 on topic Re: While I've been sitting on my backside
Polyphilla wrote: It's a chunky looking thing isn't it? :lol:
Yes Pol - it's a scale model of course and if you look at the real thing the cockpit looks big enough to hold a dance in - I'm currently starting to build the wings and figuring out what to to put in the cockpit - I might try for 3 Barbie dolls and an effigy of the Gasser in his Tutu. :woohoo: :woohoo: :woohoo:
08 Oct 2012 10:49 #4 by Phil Wood
Grumpy42 wrote: Yes Pol - it's a scale model of course and if you look at the real thing the cockpit looks big enough to hold a dance in
So this is what it should look like? .... Looks good to me. :cheer:
08 Oct 2012 13:38 #5 by Ex-Member
Replied by Ex-Member on topic Re: While I've been sitting on my backside
I like that grumps.
the trad build looks fun.
08 Oct 2012 15:00 #6 by The Beard
Replied by The Beard on topic Re: While I've been sitting on my backside
Nice build Grumps ,hope ots theraputic for you whilst you recover,
  • Dean M
  • Dean M's Avatar
08 Oct 2012 21:59 #7 by Dean M
Replied by Dean M on topic Re: While I've been sitting on my backside
Glad you are on the mend and getting some building done, looks a nice aircraft
Back in may I fractured one of my vertebrae in a car accident, I used to be the most comfy sat in my chair at my building desk, that is when I started my deagostini spitfire.
I nearly choked on my latte.
09 Oct 2012 10:21 - 09 Oct 2012 10:26 #8 by Grumpy42
I've got all excited and done a bit more - including completely changing my mind about which engine to fit ! :whistle:
After thinging about my ASP 30 4 stroke and an OS 25 2 stroke I finally settled on an unused GMS 200 25 2 stroke!
Engine box and engine mountings fitted
Surprising that such a small rudder is adequate
The Dance floor (1) :silly:
And yes - it is a bloody big 'ole innit??
Last edit: 09 Oct 2012 10:26 by Grumpy42.
09 Oct 2012 10:32 #9 by Phil Wood
Why the big boxed area directly behind the firewall? .... have you already got a fuel tank hidden away in there?
I hope you have, because if you put it behind that in the cockpit area, it will become well below the carb' line when the model is climbing & it will lean out & probably cut the engine.
I'll bet I've missed a picture somewhere. :lol:
09 Oct 2012 13:33 #10 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Re: While I've been sitting on my backside
Theres a hole into that boxed behind the engine for the tank
09 Oct 2012 13:35 #11 by Grumpy42
Polyphilla wrote: Why the big boxed area directly behind the firewall? .... have you already got a fuel tank hidden away in there?
Pol - if you look at the second last pic you will see the firewall/engine mounting box extends all the way back to the front of the cockpit bay. A fuel tank is/will be fitted inside that box. BTW - the model is built(with a few modifications) from a plan by Peter Miller that was the free pull out plan in RCM&E (August 2010).
Time to create page: 0.267 seconds
